Question about RCA P60921 60" Rear Projection Television
RCA 52 rear projector tv makes chirpping noise wont turn on
  • Anonymous Dec 21, 2008
    tv makes a chirping noise and won't come on
  • 373 Answers
You have a bad high voltage transformer. It is the white square device about 3inch square with large red wire coming out. Must be replaced with RCA original NO GENERIC. Also the horizontal output transistor must be checked to see if it is good. Recommend honest qualified tv repairman
Posted on Jan 01, 2008
When I plug the tv in it makes a beeping noise but it wont come on. what would cause that?
You are hearing the power supply trying to come up,but there is a short.....it almost like a chirping. More than likely,it will need a flyback transformer. A reputable repair shop can confirm and repair in the $200 range. If you have technical ability,I can guide you further
Jun 02, 2010 | RCA P52926 52" Rear Projection Television
G36710 RCA console TV just quit while watching... makes noise
a shorted horizontal output transistor will make a funny squeek or chirp noise when turning on the tv. Usually mounts on a metal dissipator near the bulky plastic part with the red thick wire coming out of it.good luck!
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Chirping noise
you need to replace the horizontal output transistor or the flyback. the flyback is the most likely cause. Let me know if you need more information
May 13, 2008 | RCA P52926 52" Rear Projection Television
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Oct 07, 2007 | RCA D52W19 52" Rear Projection Television
My 52 in
Chirping is usually a problem in 2 areas of this unit. 1st check 3 legged regultor on the right side of the chassis, also 2 small transisters and 2 resisters near and in front of the regulator. RCA has a kit for this problem, the second is check the horizontal output transister is on a separate heat sink along side of the Flyback Transformer, it shorts and pulls down the regulator power supply.
May 28, 2007 | RCA P52960 52" Rear Projection Television
Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Dec 11, 2006 | RCA P52939 52" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
