CAMERA WONT TURN ON. RED LIGHT GOES ON FLASHES 5 TIMES THEN WONT TAKE CHARGECAMERA WONT TURN ON. RED LIGHT GOES ON FLASHES 5 TIMES THEN WONT TAKE CHARGE
AnonymousOct 21, 2008
Same thing. I am not sure the battery ran out, but it has not been used that much...charge in the PC, but cameral will not even turn on. Has green OK light when in PC, but no power.Same thing. I am not sure the battery ran out, but it has not been used that much...charge in the PC, but cameral will not even turn on. Has green OK light when in PC, but no power.
You can't post conmments that contain an email address.
I had the same problem and purchased a new battery to resolve the problem. I also purchased a 110v battery charger for the vivitar 550 camera and recharged to old battery.
I went to their website. They didn't have any downloads available, but here is the available cust. support: [email protected], U.S # 1-800-592-9541 or U.K. 0-800-917-4831. Sorry I don't have anything else for you!
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
The easiest way is by using a standard USB cable...plug the small end of the USB cable into your camera (located under the headphone jack) then plug the larger end of the USB cable into your PC or laptop. Turn on your computer & this will charge up your Vivitar 550.
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
