Hitachi 43UWX10B 43 in. Rear Projection Television
Problem for Hitachi 43UWX10B 43 in. Rear Projection Television
Press power button just clicks, no power. Found
By ppetana on Oct 23, 2009
Press power button just clicks, no power. Found this similar problem listed on website, but I have additional questions in regards to taking voltage readings. I tried looking for schematics but no luck. Can you help me define locations for taking readings and what is expected? I was given this unit in hopes to saving it. Previous owners had power supply changed. Like to verify voltages to elinmate PS and start looking at Convergence O/P IC's? What is next possible component? Would like direction.
Comments:
Nov 06, 2009
- I checked the resistors and found no discoloration. As I was unsoldering the STK's I notice there was one that had a wire solder to a diode (DK25 to STK,IK04 Pin #1). This didn't look like it was done from the manufacturer as is wasn't bonded to the PCB. Any comment on this? I also noticed a red led (DP06) on the Deflection board coming on after plugging in the unit. What does this indicate? Any additional advise? Thanks for your help.
Nov 06, 2009
- Sorry I forgot to mention about trying the unit- No the set didn't not turn on.
Best Solution
posted on Oct 23, 2009
Helpful)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 914 votes
The best thing to do here that is easy-----get at the two STK-392-110 CHIPS and un-solder both of them--if the set then comes on--one is bad--you might also take a close look at all the low value resistors around them--all have location numbers on the top of the board--like RK51 etc.
If you find a discolored resistor--or if unsoldering the chips lets the set turn on----you have found your problem.
Let me know if you have questions or need help--I am here to help people.
SD TECH
Comments:
Nov 06, 2009
- The jumper belongs there--it is usually a green wire and goes to pin on one of the chips.
Did you try to turn the set on with the chips unsoldered?
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Hitachi 43UWX10B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43UWX10B 43 in. Rear
Do you recommend Hitachi 43UWX10B 43 in. Rear Projection Television?
Answer
Answer
Red light was on (next to the blue power light) when we attempted to turn on our TV. It appears to... (More)
Answer
power went out when tv turned back on double images 52 inch hitachi
Answer
green, pink color waves at top of screen and wording on screen is double
Answer
rear projection tv made pop noise then picture and sound went out. power light is on.
Answer
I have a Hitachi Ultravision HDTV model number SP-43w. When you turn it on it is red and wavy across... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 43UWX10B 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
