Question about ViewSonic N3250W Television
Power light comes on - but NO IMAGE.. Power supply / inverter???
I have an issue where the tv status light will come on, but there will be no display. After a few seconds the tv seems to produce a soft high pitch squeel, that seems to be coming from the vicinity of the power supply board - which is a Darfon 4H.B0280.001 / C2 board... In talking with viewsonic support they thought it "might" be the B-00005963 power supply, but not %100 sure.
I have the back panel taken of and looked at the power board, but nothing looks toasted. I found that there is actually current flowing through the heat sink on this board when the switch is engaged (learned this the hard way)......
Does anyone have the service manual for this or have any ideas on what to do to trouble shoot?
Any ideas?
The power suppy  no works no good the capacitors no good
Posted on Sep 14, 2008
You have to make sure the power supply works.first make sure there is no current flowing to the circuit disconnect it from the power source.then use the multimeter to diagnose all the diodes at secondary power supply.if there is any that has loose the value or connecting direct replace it if not check the transistor that is at the fly back contact me at kenonarnold@yahoo.com if not successful
Posted on Sep 03, 2008
At first my tv would work for about 8 hours, then the backlight and audio would die. The light stays green like it is on. now it will work for an hour before it does it. I'm guessing it is the related to this problem. On the viewsonic store they have the PSU board, However it is out of stock. If you can get them to send you the part It is an extremely easy fix. As soon as I find a power supply I'm going to see if works.
Posted on Jan 07, 2008
Westinghouse ltv-46w1 hd
Test the various power supply voltages first if your able to be sure they're ok, if they are it could be the main or Tcon board that is bad
Mar 20, 2018 | Westinghouse Televison & Video
Why am I not seeing an image on my TV
Do a hard reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 24, 2016 | Sony Televison & Video
Videocon Sapphire VAD32HH-NF LCD tv - Giving no display issue but sound is coming
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 25, 2015 | Washing Machines
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
Apex LD4088 LCD Power but no picture
If you have replaced the inverter board and the power board with known good parts the the panel itself is bad.
May 31, 2013 | Apex Digital LD4088 LCD TV
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
I have a Sharp LCD TV that is not quite 2 years old. Last night, while watching, the set turned itself off and the green power button kept flashing. I read that someone else had this problem, and tried the...
Hi
Thanks for using FixYa. As you have already tried the reset procedure so to check what has gone bad you’ll have to open the back of the unit and check the backlight inverter board. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. If not then check the power supply board however, it seems to be the inverter board as the sound is still working fine.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Televison & Video
Tv not powering on
Problem seems in power supply or back light inverter boards and needs to be tested with another same boards.
You can get power supply and back light inverter boards from Shop Jimmy.
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Monitor goes black but the green light stays on. I turn the power button off and then back on and it comes back on. It may stay on for a few seconds to several minutes.
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on green, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
The inverter is the board that supplies power for the backlights to turn on. The backlights
provide a light.for the LCD Panel(provides color and is the logic. ... similar to a projector.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
Sep 18, 2008 | Computers & Internet
Gateway FPD 1830 LCD Monitor
User "noclew1"
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on, but the back lights are what helps support an image from the Front Panel Display.
As for User Guest
Your issue is nearly the same issue when it turns off on you. But the doubling effect is from the power being supplied by an old or weary power outlet to an FPD. That can be the cause. Try different locations.
Well I wish you both luck and I hope this solution can help you with the problem.
Thanks
Victorsinferno45
Aug 30, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Televison & Video Logo
935 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
