Question about Cameras
Digtal camera blueprints
Looking 4 blueprints 4 camera and vioce recorder
Haha
Posted on Sep 18, 2008
Can you get a vioce recording
Yes. You can start recording voice call when the call is connected by touching the red dot (•) or direct start recording option.
Nov 29, 2016 | Cell Phones
Recording with a Digtal Voice Recorder
Your telephone does not contain a special connector for this type of device. Besides, I wonder if your voice-recorder has a connector for this, like a mic-in. If there is, you can consider to buy a special electronic device, which taps the audio from the telephone-line and hook it up to your digital voice recorder.
Also, you can do it without this electronic device, but requires electronic knowlegde and tools.
If the phone and the voice-recorder both miss a connector to connect to each other, you can always go for the handsfree-mode of this phone and activate the voicerecorder when there's an incomming call..
Oct 14, 2013 | RCA Executive Series 25404re3-a 4 Line...
I am running two 15 spl soundstream woofers with a soundstream 500sx amp how do I bridge them to get maximum performance
the 15 spl woofers are dual voice coil, i believe 2 ohms per voice coil.
the 500sx amp is rated 4 ohms bridged at 500 watts, it is capible of dropping to 2 ohms sterao, but no lower than 4 ohms bridged. to get maximum performance, you cannot use both voice coils of both speakers, you can only use one speaker, or both speakers, while only using one voice coil from each.
there is no point of bridging them, you can achieve maximum performance by attaching one voice coil from each speaker to each channel of the amp, while leaving one voice coil from each speaker unconnected. you could also use just one speaker, attaching one vioce coil to one channel, and the other vioce coil to the other channel. then, i would suggest getting a second, identical amp to run the second speaker.
if you are persistent on bridging to mono, then you can only use 2 voice coils (both from one speaker, or one from each speaker) and you must run the voice coils in series, that is, from the amp positive to the 1st vioce coil positive, then run a jumper wire form the 1st vioce coil negative to the 2nd vioce coil positive, then, finally, run the 2nd vioce coil negative back to the negative of the amp.
this is all assumming that each voice coil is 2 ohms and each vioce coil has seperate inputs, meaning that each speaker has 2 pairs of speaker terminals.
Oct 08, 2009 | Soundstream SPL 15 Car Subwoofer
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
Transferring hi8 tape to Everio hard drive
I play the hi8 video back to the T V lcd 32 screen
Because you video in not in digtal format
From the Telly i set up the try pot install the camcorder jvc 30
everio zoom in to size start the camera camcorder
for video start the hi8 video in the telly pres the recorder
on camcorder and record. This is the way the piratcy is done in the Cinamas
corra
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Voicemail passcode
Both of these problems can be cured by calling a tracfone operator. You will not loose the recorded vioce mails that way.
Dec 12, 2007 | Motorola Mobility TracFone C139-4 Cellular...
Cameras Logo
392 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
