Home | Bosch | 24 in. SHU66C02 / SHU66C06 Built-in Dis... | Dishes don't get cle...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Problem for Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Dishes don't get clean, dirty
By harwood_jeff on Oct 23, 2009
dishes don't get clean, dirty water stands in bottom of dishwasher - looks like coming from disposal/sink
Comments:
Oct 23, 2009
- also wanted to mention that dishwasher will drain if I run a clean cycle on the dishwasher. Also, appears that water from the connected disposal is flowing back into the dishwasher...for example I cleaned out a coffee filter in the sink and dirty water w/ coffee grounds was in bottom of dishwasher.
Oct 23, 2009
- dishes don't get clean and dirty water stands in bottom of dishwasher....will drain if I run a clean cycle on the dishwasher. Also, appears that water from the connected disposal is flowing back into the dishwasher...for example I cleaned out a coffee filter in the sink and dirty water w/ coffee grounds was in bottom of dishwasher.
Solution #1
posted on Oct 23, 2009
Somewhat Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 1979 votes
you have a blocked drain pipe. begin by snaking out the drain and disposal at the sink level. then run the dishwasher empty to see if it is draining properly. if you still have water sitting in the bottom of the dishwasher remove the kick panel on the front near the floor. Then you will see the drain hose and the small pump that drains the dishwasher. Chances are if you get this far, there is debris caught in the pump, like a piece of glass or bone. good luck with it.
Solution #2
Not Rated)
roniecon
Rank: Guru
Rating: 88%, 637 votes
Sounds like the main drain is stopped up.The problem is that the water can not drain from the dish machine,because of a blocked main drain .The drain is blocked under the disposal,This may be a bigger job removing the disposal.Is water standing in the disposal?Most likely the disposal will have to be removed to access the main drain under the disposal.Once the drain is clear,run the dishwasher empty,with about a cup of bleach,If you have a choice on hot,warm,or cold water on the dishwasher,choose the hot selection.This will clean,and sanitize the machine.I hope I shed some light on the problem at hand,if I did,please let us know thank you.
Popular Solutions for Bosch 24 in. SHU66C02 /
Questions and Unsolved Problems for Bosch 24 in. SHU66C02 /
Do you recommend Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher?
Answer
Answer
bosh dishwasher wont fill...also sink drains right into dihwasher ....
Answer
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from... (More)
Answer
Power problem with the bosch dishwasher model shu43c02uc
Answer
I can't find my manual so I need to review how to load the dishwasher the correct way. I feel I am... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C02 /...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
