Question about RCA RS2640 CD Shelf System
RCA Stereo I have no sound And The tape player will not come on. The two NTE7186 audio output transister have been replaced. What do I check next. Thank you Mr. Roe
  • 5 Answers
SOURCE: no sound
check tranistor 2sc3203y (q401)/replace with nte 382/it fixed my problem
Posted on Aug 24, 2008
0 characters
1 Points
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
I want to wire a subwoofer and amp to player
1. cd player connection, audio out (stereo) rca cable
2. from cd player rca cable, connect it to amplifier audio in (stereo).
3. speaker output wiring connection going to spkr. box.
Apr 16, 2010 | JVC FS-2000 Shelf System
How to play my ipod through this stereo
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
Am trying to hook up an older kenwood home stereo system and dont know where all of the wires go. There is a model #kt-87synthesizer, km-207 amplifier, double cassette kx-77cw, stereo control amp kc-207...
Okay you are going to need 5 sets of RCA cables of 3 foot lengths. Ensure the KM-207 is adequately ventilated unless you want to burn up the KM-207. Next you will want to place the KC-207 near the KM-207 and connect the "Output to Amp" from the KC-207 to the "Input" to the KM-207. Now you may stack the KX-77CW, the DP-M97 and the KT-87 Tuner in no particular order. I tend to place them sideways so I may access them just in case I don't like how it is set up. Unless I can access them from the back. "Output" or "Play" from the DP-M207 goes into the "CD Input" in the back of the KC-207. "Output" or "Record" on the KC-207 "Tape 1" goes into the "Input or "Record" on the KX-77CW. "Output"or "Play" on the KX-77CW goes into the "Input" or "Play" on the "Tape 1" of the KC-207. "Output" on the KT-87 Tuner goes into the "Tuner Input" on the KC-207. Here is a trick to help you new stuff uses color codes such as White or Blue RCA cable ends, and Red RCA cable ends to indicate White or Blue for Left channel and Red for Right channel. Now you didn't indicate how to hookup speakers so I will not assume you are concerned about anything but using headphones for listening. I hope this has been of assistance.
Aug 29, 2009 | Kenwood Audio Shelf Systems
I have a rca rs2640 stereo system. The display, cd player, tape player, radio, and headphone jack all work. But when a cd, tape, or radio is playing, the speakers do not make any sounds. I know it is...
It sounds like maybe you have speaker wires touching somewhere. If they are touching it will blow fuses, especially if you turn the volume up to try to hear anything. DO NOT put bigger fuses in to replace the old ones, you will actually do more damage to your system because a higher volt fuse will allow a higher voltage to "spike" in your stereo and might just start frying internal parts.
Aug 10, 2009 | RCA RS2640 CD Shelf System
Loud buzzing when I insert a tape in my car's stereo
Hiya, first try a normal cassette, see if that plays OK. If so the deck is probably fine, if not then the deck is faulty (probably not serious though and just a loose wire on the head).
If the connection between the tape and MP3 is a cable, the fault is quite likely there (if bluetooth then not). I strongly suspect the cable from the previous issues also.
Best of luck
Jul 15, 2009 | RCA RS2640 CD Shelf System
Is it possible to connect my panasonic sg-hm22 to my Denon Reciev
You need an "Audio Output" ie. Tape 2 mon or Rec out (RCA jack) on the Panasonic for it to work. Hope this helps
Jun 22, 2009 | Panasonic Audio Shelf Systems
No sound from tape player
HEY EVERYONE WHO HAS A PROBLEM WITH A RCA RS2640 STEREO!, if u have this problem all you do is take it apart and then find the control panel and get like a credit card or something, you should see a chip placed near the control panel all you do is get the credit card and gently scratch it with a credit card for 30 seconds and then it should work!!
Jun 26, 2008 | RCA RS2640 CD Shelf System
Home Stereo System
Sounds like a internal error on the amp itself. Maybe it caught a surge, I had a stereo unit that got zapped by the way it was unplugged from the wall.
Mar 25, 2007 | RCA RS2640 CD Shelf System
RCA RS2640 CD Shelf System Logo
22 people viewed this question
Top RCA Audio Shelf Systems Experts
Jaime Hernandez
Are you a RCA Audio Shelf System Expert? Answer questions, earn points and help others
