it washes rinses and spins just fine but when the water empties it makes a horrible sound. the water empties efficiently, i don't think it's the drain pump. it's almost as if gears are not aligned somehow. help! it's less than 3 years old
i have a sole motor from a front loading washing machine that i would like to use on the spin cycle...
(More)
i have a sole motor from a front loading washing machine that i would like to use on the spin cycle only (for another purpose) but the wiring diagram is no where to be found. Which of the multiple wires is for spin mode sole model 205850 model of washer not important or accurate
My washer will stop in mid cycle and then I have to push the start button again and it starts where...
(More)
My washer will stop in mid cycle and then I have to push the start button again and it starts where it left off at. How do I fix this problem it is a brandnew washer
My almost new Frigidaire GLTF2940FS2 washer makes loud buzzing sound in the Permanent Press position...
(More)
My almost new Frigidaire GLTF2940FS2 washer makes loud buzzing sound in the Permanent Press position "normal" position and won't start. Switching to "heavy" position, machine starts.
front loading Firdgeaire washing machinge has a lot of play front to back could. the drum is...
(More)
front loading Firdgeaire washing machinge has a lot of play front to back could. the drum is anchored a 4 points. the top two are with springs, the botton two points are anchored with some sort of shocks. Could those shocks be broken?
