Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch Nexxt 700 spin problems
We have had our washing machine for approximately 9 months and I have begun to notice that some loads do not spin at the full speed and when the machine finishes the clothes are still quite wet.  The cycle completes and it goes through a long spin portion but it never gets up to full speed (800 to 1200 rpm depending on the cycle chosen).  It begins spinning gradually faster and faster and then slows to near stop the speeds up again for a bit then slows down (I assumed this was part of the process to redistribute the load so that it would be in balance before going high speed).  This process continues for several minutes and sometimes it takes off to full speed and sometimes the cycle finishes without ever getting to the programmed speed.  Is this normal? Thanks in advance.
  • 3 more comments
  • jay thornton Jan 08, 2008
    same problem, but we also get an error 3 code. I've cleaned out the "trap" at the bottom front right of the washer, and this does not seem to fix.
    we are in the country, so our drain to our septic is 6 feet or so above the washer, and in a different corner of the house, to install the drain, I installed clear tubing that goes up 8 feet, through a one way "trap" valve, and then into one of the main waste water lines on our basement ceiling...it worked fine for the first year, but is this the problem?
  • Anonymous Aug 19, 2008
    when the electricity goes off and on the washing will not spin .
  • chinny50 Sep 03, 2008
    I have the same problem with my wfmc640suc front load Bosch washer. Anyone else have this problem and what was done to fix it?
  • Anonymous Sep 10, 2008
    My clothes remained soaking wet and never got up to the full spin 800 rmp on my 100 model. Only one sweatshirt in load, so it can't be a balance problem right?
  • Anonymous Mar 16, 2014
    Bosch Nexxt 700 Washer will not reach full 1200 RPM spin speed.
  • 183 Answers
Yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Posted on Dec 30, 2007
Can i stack the nexxt 700 series machines?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosh neither spin nor drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Why is there water (up past the fill line) in the fabric softener dispenser when the wash cycle is complete? I have become accustomed to emptying it prior to each new load? i typically run the load on...
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 30, 2010 | Bosch Nexxt 700 Series WFMC6401UC Front...
Not draining
Clean out the lint draw and then run vinegar through a cycle.
If this doen't work try CLR. or/and put the drain hose to the lowest level and then put a flexible clear tube down to unblock it.
Use less detergent in the machine. I make my own detergent and I don't have any problems as one of the ingredients in it help keep all lines clear.
If that doesn't solve the problem contact Bosch directly.
Jan 08, 2008 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
734 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
