Question about LG 42LC2D 42 in. LCD HDTV
Remove Swivel Base on 42LB1DRA
Hi, My instruction manual doesn't tell how to remove the base so I can mount my Flat Screen LCD on the wall. Can you help???
  • dalewpotts9 Jan 01, 2008
    I have a model th-42pd25 panasonic tv and cant get the base off to wall mount, can you help me
  • 52 Answers
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
Posted on Jan 05, 2008
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
How to remove base on samsung 2333hd. The base comes un mounted butcan't figure out how to remove the stub sticking out of the bottom of the tv for wall mounting
We had the same problem, we just wiggled it back and forth, gave it a good tug, and hey presto! We got it out. I'm not sure whether this is the "official" method of doing it, as nothing is mentioned in the instruction manuals.
Dec 26, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I'm trying to wall mount my Proscan 19LB30Q LCD. According to the manual, to remove the base, you simply take out 3 screws from the back near the base and pull out the stand gently. I can't remove the...
Although the instructions don't mention this, you also need to remove two screws on the bottom of the base. Pull the base bottom off. Then remove another screw that holds the base post on.
Nov 17, 2009 | Proscan Televison & Video
Not sure how to take the swivel base off for wall mounting on a 42lb1dra
Dec 07, 2008 | Computers & Internet
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
LG 42LC2D 42 in. LCD HDTV Logo
451 people viewed this question
Computer Repairing
Computer Repairing
