Question about Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
Hey, just got a Tosiba Satellite w/ Windows Vista, 2G RAM, 200GB hard drive...tried to add Gears of War and a Logitech Rumblepad 2 to do a bit of gaming...the Rumblepad works, but my directional toggle (joystick) to move foward/rev, and strafe left/right is backwards when using fwd/rev...down is foward, and up is rev. When is switch controls to directional as being the right toggle (joystick), the controls are correct...tried to use the driver software to fix this prob., nothing came out of it....same direction still....hit me up @ if anything is found....didn't know until after I bought all this shit how bad Vista blows! Gotta deal with it now...
Re: Gears of War for Vista and Logitech Rumblepad 2...
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Posted on Jan 05, 2008
You must edit the C:\Program Files\Microsoft Games\Gears of War\Engine\Config\BaseInput.ini and change the values from:
Bindings=(Name="XboxTypeS_LeftShoulder",Command="obj list")
Bindings=(Name="XboxTypeS_RightShoulder",Command="obj list")
Posted on Jan 12, 2008
0 characters
3 Points
Logitech Profiler detection issue.
plz contact with microsoft support for the problem...
Feb 07, 2010 | Logitech Rumblepad 2 Game Pad
Logitech Cordless Rumblepad 2
You need to set up profiles to use this gamepad. I ve made several profiles. Most downloaded are Call of duty MW 1 & 2 and NFS Shift setups. Download them here if you need them:
COD 4 MW and COD 6 MW 2
NFS Shift
Oct 10, 2009 | Logitech Cordless Rumblepad 2 Vibration...
When I plug my Usb Logitech Rumblepad 2, it says that the usb device is unrecognized.
Try another usb port on the computer. If that doesn't do it try another computer, and if the problem still there then it is the controller.
Aug 10, 2009 | Logitech Rumblepad 2 Vibration Feedback...
Rumblepad 2 can't move
Do you still have the receipt?
Dec 25, 2007 | Logitech Rumblepad 2 Game Pad
Gears of war problem
Simple fix for forward-back movement axis inversion:
In "My Documents\My Games\Gears of *** for Windows\***Game\Config", edit the file "***Input.ini". At the very top, under the section "[Engine.PlayerInput]", change your MoveForwardSpeed to a negative number, like this:
Note that I only play offline, and this setting in this file works great for me with Logitech Rumblepad 2 (although all of the other buttons are still a little off, but that I can live with). I tried every other reference to forward-backward movement and the left Y axis in this file, as well as "<installdir>\Engine\Config\BaseInput.ini" and "<installdir>\***Game\Config\DefaultInput.ini", so don't bother with those...
Dec 08, 2007 | Logitech Rumblepad 2 Game Pad
Getting the logitech rumblepad to work with Valve Games (Portals)
Hey just Download LGS501.exe .(Search for it in Google) and install it.This is Mainly For Win Vista(Even though it will Work 100% on XP) .
If You have any Questions . Or If you Want any Drivers , Softwares,Games,Help,Firmware,Patches,Serial Numbers JUST Email to my account ------
With Your Problem Or The Thing You Need.I Will Send it As Fast as Possible as a Reply to your email account which you sent to me .
Nov 29, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Vista drivers
Me too. Can anyone help please? I already mailed Logitech for this.
Nov 10, 2007 | Logitech Force 3D Pro (963352) Joystick
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO ---
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Logitech  Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758) Logo
3,326 people viewed this question
Top Logitech PC Game Controllers Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Logitech PC Game Controller Expert? Answer questions, earn points and help others
