Question about Refrigerators
Refrigerator water leaking into bottom of refrigerator
  • 1 more comment
  • sophieDorion Jan 12, 2008
    Experiencing same problem. Should I unplug for a while & restart? My home location experience quite a bit of power failure, do you think this can have something to do with this?
  • Morito Mar 23, 2008
    Water is leaking from the bottom of my Amana ref.
  • jennymorrs Dec 02, 2008
    drain plug clogged,where is drain plug?moffatt upright refrigerator
I had the same problem with my whirlpool fridge....
there is a overflow drain at the bottom of the freezer compartment.
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Posted on Apr 15, 2009
  • 283 Answers
The problem you describe is common but without knowing the make/model I can only answer in broad terms. Water in the fridge section is almost always caused by a clogged defrost drain. Service is different depending on the mfgs but commonly the drain gets clogged by ice or some foreign object. For ice jams, on brands like GE or Whirlpool a "heat transfer device" is available which clamps on the heater and extends into the drain, providing extra heat to allow drainage without refreezing. For solid items, blowing back on the end of the drain hose in the drain at the bottom with compressed air works wonders.
Posted on Dec 31, 2007
I just fixed a clogged defrost valve in on my bottom freezer GE unit. For anyone else who has one, here's what I did: (You'll need a caulking gun)
Unplug the fridge.
Behind the fridge, there's a large cardboard housing at the bottom held in with flathead screws. Take it off.
This should reveal a black rubber tube which flows into a drip tray. At the other end of the rubber tube is a metal housing held in with phillips screws. Take off the metal housing.
Now detach the rubber tube from the drain valve and flush it out. If that didn't solve the problem (and it probably won't), take the screws out of the drain valve and take it off of the fridge. It's sealed with caulk, so you're going to have to wrestle with it a bit.
Now, flush out the drain valve. (I ran hot water through the small end, where the hose was attached, and a lot of awful things came out of the big hole in the back.
Don't forget to remove the old caulk from the hole and replace it with fresh caulk to seal the drain valve back onto the fridge.
Now just replace everything and plug it back in!
Posted on Jul 29, 2008
I had this problem and solved it.
The advice is correct in that the drain was blocked however what I found was that when I looked at the drain tray at the back there was algae growing. I cleaned the tray and put a couple of drips of bleach in it. 2 years on I have not had any further problem.
Posted on Jul 03, 2008
4 Suggested Answers
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
  • 21 Answers
SOURCE: water leaks into bottom of refrigerator
defrost drain was clogged , unclogged drain solved your problam
Posted on Oct 14, 2009
smuschanow
  • 20 Answers
SOURCE: WATER LEAKING IN BOTTOM OF REFRIGERATOR UNDER VEGETABLE KEEPER
This sounds like the problem I responded to for another user. I hope it works for you. I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Posted on Nov 25, 2009
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
I have water on floor under refrigerator.There is no water supply line to this frig.
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Water leaking from the bottom
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 16, 2009 | Refrigerators
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
2,268 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
