Question about Dayton (3E386) Heater
Dayton 3E227A Heating Cycle
I have an old 75 K BTU Dayton shop heater in a large (approx 24' x 48') garage. For the last two years it has started to produce heat only in short cycles. The burner will come on for a time, maybe up to two minutes and go off as the fan comes on. The burner will then immediately come back on for a short time and again shut off as the fan cycles on. It will repeat these short cycles until the thermostat senses the set temperature. The heater did not work this way before. It used to run continuously until the set temperature was reached. What could be causing this change in operation?
  • newsomer Jan 07, 2008
    Thanks, I'll check the connections and try to find the internal sensor to see if it needs cleaning or replacement.
  • 579 Answers
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Posted on Dec 31, 2007
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide -
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
Have Dayton 3e227a gas heater fan has quit, need new motor, can you supply source to buy? Tim
Dayton is a Graingers Brand. Go to the site below and I'm sure you can find your part. Put in your Part Number...Jim
Feb 18, 2011 | Dayton (3E227) Gas Radiator Heater
Trying to find a replacement fan motor for a dayton electric garage heater moodel number 3e547 its around 12 years old
Go to grainger then go to dayton heaters with your model number and part number if you can find it,along with description of parts you need. I have been dealing with them for years and they are the main distributor for dayton furnaces.
They carry a large selection of parts and generally ship within two days. Hope this helps you. Thank you.
Jan 27, 2011 | Dayton Electric Heater
Is there any place to get a heating element for an OLD Dayton Electric Garage Heater..... model 3E087..... 240V, 10,000watt. It has a circular heating element, and only the inner most part of the element...
I think your best bet is to go to and go to repair parts for dayton furnaces with your model and serial number and part no. if possible. You can also call1-800-323-0620 and get location of dealer nearest to you.
I have dealt with them for many years and they have always treated me right.Not always the cheapest but I have been happy with the service and the expertise of their staff. I hope this helps you and have a good new year.
Thank you.
Dec 27, 2010 | Dayton Electric Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I have a 25,000 BTU hanging furnace, will this heat a 900sq foot garage that has been insulated.
Here in Vermont we design heating systems to perform at -10 to -20 degrees. Depending upon how tight the doors and windows are, it may if your temperatures don't drop below 20 degrees. It may take a while to heat up and I would not expect any temperature over 62 degrees inside the garage. Maybe a 50,000 Btu heater? Remember the output may be 20% less than the rated input of the heater.
Dec 29, 2009 | Dayton Gas Furnace Heater
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Dayton (3E386) Heater Logo
590 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
