Question about HP LaserJet 4100tn Printer
Error 51.1 HP 4100
Receiving error 51.1 on HP 4100. Maybe laser scanner issue (parrt RG5-5100
  • Anonymous Mar 21, 2014
    flashing data received not printing
    President:
  • 787 Answers
Error 51.X is a loss of beam-detect occurred.Possible reasons:
1 - Beam-detect error
2 - Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Posted on Oct 23, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have a HP Laserjet 4100N with an error code 51.2. What part do I need and is it something I can do myself after receiving the part?
http://www.printertechs.com/printer-troubleshooting/401-51-01-51-1-error-hp-laserjet-4100-laser-scanner-failure
Jun 28, 2016 | HP LaserJet 4100n Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
Message error 51.23 on hp color laserjet cm2320nf
The 51 refers to a laser scanner error. The 23 refers to the yellow laser scanner.
Turn power off. wait 30 seconds. Power up and monitor. If the error reoccurs, your printer
is going to need a DC Controller.
Mar 02, 2011 | HP Laserjet CM2320nf All-In-One Color...
The printer is showing error 51 and not printing
Control Panel message
51 PRINTER ERROR
Description
Beam error
Action
Laser scanner cable connectors are faulty or laser scanner assembly is defective Most likly it is the laser/scanner assembly. The motor is probably not spinning at the right speed. You would need to find an old hp 4 no longer working and switch the laser/scanner. It is the "black box" located under the top cover. You would need to remove the right side cover, the top cover, the left side cover and the output assembly. Remove all the cables from the scanner retaining clips. Remove the three cables plugged into the scanner and remove the four screws attaching the scanner to the frame. When replacing the scanner make sure the shutter control arm on the left front side of the scanner is attached correctly so that the shutter closes when the toner cartiridge is removed. You could first try to remove the 3 connnectors and reset them.
Nov 17, 2010 | HP LaserJet 4 plus Printer
HP Color LaserJet 2605dn_2605dtn error code 51.22
The 51.xx error occurs when there is an error in connection with the laser, if you open the printer to clean the lens, surely you have forgotten to replace the cable connection purple laser. open it again and reconnect all cables OR: 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 06, 2010 | HP LaserJet 2605DTN Color Printer
My printer shows 41.2 errors
Hope it helps
1. A temporary printing error has occurred.
2. Press GO. The page containing the error will automatically be reprinted.
3. Reseat the connections to the laser scanner and then to the engine controller board.
4. Replace the laser scanner.
5. Replace the engine controller board.
Jul 08, 2009 | HP LaserJet 4100 Printer
My printer shows printer error 52.0
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
Aug 30, 2007 | HP LaserJet 4p Printer
HP LaserJet 4100tn Printer Logo
1,860 people viewed this question
Clive
Clive
