Home | Gaggia | Titanium Espresso Machine | The message ven...
Gaggia Titanium Espresso Machine
Problem for Gaggia Titanium Espresso Machine
The message ventilate is showing
By ttittler on Oct 22, 2009
the message ventilate is showing and the machine won't work at all. It started when we used the steam to froth milk.
Best Solution
posted on Oct 23, 2009
Very Helpful)
Stian S
Rank: Apprentice
Rating: 100%, 2 votes
As pointed out by bansheracer, "Ventilate" means you need to open the valve on the right to let out some steam from the milk steamer wand. This can also happen if you accidentally push the 'steam' button but don't actually let out any steam.
If it is stuck or needs cleaning, unscrew the metal piece and dip the plastic bit in a jug of hot water - it should resolve most of the dried milk in about 5-10 minutes.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
bansheracer
Rank: Guru  Kitchen Appliances  Expert
Rating: 92%, 173 votes
Hi
If you can't get water out of the wand, the ventilate won't go away. If you can't get water from the wand you have a blockage in the steam tip and it just needs to cleared and you will good to go. If you can get water out of the wand and you get a forceful stream, your flow meter is bad. If you can get water from the wand but the flow is slow, you have a restriction in the flow meter. It needs to be removed and cleared to work again.
Was this helpful?
Yes
No
Popular Solutions for Gaggia Titanium Espresso
Questions and Unsolved Problems for Gaggia Titanium Espresso
Do you recommend Gaggia Titanium Espresso Machine?
Answer
Answer
Hi, I would like to purchase part for my gaggia titanium: 49 §222630437 Cerniera sportello... (More)
Answer
Hi i have on the screen grinder blocked, i have clean it out and checked the grinder motor its ok.... (More)
Answer
The ventilate button is not working. the machiine needs to be ventilated but when i push the... (More)
Answer
Hi. I need a water tank for a Gaggia Titanium SN 0105075623. It's the clear plastic one that fits at... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gaggia Titanium Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 886
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
