1. Turn the printer off, wait 10 minutes, and
then turn the printer on. 2. If the message persists, reseat the fuser.
If that does not work, replace the fuser. To check the fuser, turn
the printer off and remove the fuser. Measure the resistance between
the fuser connectors. If it is not within the proper range, replace
the fuser. If there is not continuity between the fuser connectors
neutral and hot with the fuser removed, replace the fuser. If the
problem is not related to the fuser, replace the engine controller
board.
Was this helpful?
Yes
No
Popular Solutions for HP Color LaserJet 3500 Printer
I recently started getting about a 3 inch wide black streak vertically down the center of my paper....
(More)
I recently started getting about a 3 inch wide black streak vertically down the center of my paper. I have an HP 3500. I'm not getting any error messages on the printer or that anything is low.
Have recently had problems with vertical streaking on a document with a large amount of color...
(More)
Have recently had problems with vertical streaking on a document with a large amount of color coverage when printing larger runs (50). Two toner cartridges were replaced during the printing process. What could be the cause? Thanks.
HP 3500 has a vertical intermittent smudge about 1/8" wide. Can I clean the filament on the...
(More)
HP 3500 has a vertical intermittent smudge about 1/8" wide. Can I clean the filament on the inside of the door where I can see it is coming from?
I just replaced a magenta cartridge and now I am getting intermittent streaks down the page, about...
(More)
I just replaced a magenta cartridge and now I am getting intermittent streaks down the page, about 18" wide. When looking at the open door where the cartridges go in, there is a streak on the on the surfaces of the ???? on the door. Can I clean these surfaces?
