it's like my whirlpool is not getting any water...it was working fine yesterday and today when I started it I opened it after the cycle was done - the dishwashing liquid was pooled at the bottom and the dishes were still dirty help?
on the bottom of the inside remove bottom rack and you will find a plastic float. it is most likely stuck in the up position. jiggle shake , turn and it should go down and allow it to "think" it is empty to allow fill. good luck, let me know.
Hello, your problem is going to be with the inlet valve. Remove the kick panel at the front bottom of the dishwasher under the door, turn the water and power off. You will see the inlet valve normally on the left side underneath your dishwasher (sometimes on right) connected to the water supply. Remove the water supply hose/pipe and then remove the wire harness from the valve. Now you can remove the valve from the machine. Just inside the inlet there should be a screen...check this for debris. If debris found clean out and reassemble, If no debris replace the valve and then reassemble. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool GU2400XTP Built-in
