Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
