Question about RCA DRC6300N DVD Player/VCR
DVD DRC630N WE have a portable DVD player and when you put a disk in it it might play for a little bit but then stops and won't play again. It will either read disc error or no disk. What could be causing the problem? I tried using a cleaner disk in it and it won't even read the cleaner disk.
    Problem Solver:
  • 5 Answers
Hey, this looks familar. Here's the same answer (first)....
Sometimes this is a dirty surface on the Disk. Watching it with a soft cloth and non-abrasive 'gentle' dish soap can help. At least, that's what Netflix tells me to do with them.
If it's happening on EVERY disk, and all you're playing are commercial, new, pre-recorded DVDs, then there's more things to try. Some links from reputable sources:
http://www.techlore.com/article/10478/
http://www.ehow.com/how_2036277_fix-error-dvd.html
After all that fails, it's probably time to change the DVD drive inside the player. Sometimes this is easy, sometimes not. :) with the DRC 630N, this would be more in the 'not' arena. :)
Of course, if you have a valid warranty, then when you're left with no solutions that don't void the warranty, you have to decide whether to try to pass it off to the warranty holder for repairs.
But, with more information....can you still play the games that this unit comes with? Assuming so, then the problem is probably one of alignment of the read sensor. This is generally a repairman fix.
Posted on Apr 03, 2008
We got mositure under the screen, how do we get it out?
this is a bit technical to do , you need to carry it to a repair shop...
Sep 01, 2012 | RCA DRC630N Portable DVD Player
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Jul 04, 2010 | Audiovox D1718PK Portable DVD Player with...
Glitch with the power jack on our DRC630N
Return it for warrenty sevice,the connection jack port ave some kind of shorts.
Jun 29, 2009 | RCA DRC630N Portable DVD Player
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Says no disk
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
DVD player won't work
same problem as above===put disc in and get no disc or error disc also mine will read then just stop
Dec 30, 2007 | RCA DRC6300N DVD Player/VCR
RCA DRC6300N DVD Player/VCR Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
