Question about Fuji FinePix S7000 Digital Camera
ZOOM ERROR Just started..cannot seem to get it to work. Is there a solution other than buying a new camera?
My camera turns on and I can view the pictures I have taken, but when I try to shoot a new picture the message "zoom error" comes on and the lens does not move. Anyone can help?
Posted on Mar 08, 2008
  • 3 Answers
What just started? The camera? Do you have fully charged batteries? Did you check the manual?
Posted on Jan 08, 2008
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Zoom error
I had the same problem with my 6-month old Olympus SP-560UZ  and was quite upset until I thought of a way around this. The error seems to be due to the lens becoming off axis and not extending. I was able to turn on the camera by lying it down flat on its back so the lens will extend straight up when the camera is powered up. Once it is turned on, it seems ok to move it back in its normal position.
So far so good - and it is free…
Sep 19, 2008 | Cameras
ZOOM ERROR
Fuji will replace it, contact them. I had to replace mine 4 times, and they finally sent me a new camera. Now, I am also experiencing the lines across my photos with the new camera. It seems like they have many faulty products.
Jun 18, 2008 | Fuji FinePix E900 Zoom Digital Camera
Nikon coolpix 775 digital camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 02, 2007 | Nikon Coolpix 775 Digital Camera
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
Zoom Error
We had the same problem with a Fuji FinePix s3000 purchased almost three years ago. Its been a terrific camera and has worked perfectly until just last week when it came up with the "Zoom Error!" problem in the view finder. Since then we have not been able to take a single photo. We did not expose it to any extremes of heat or cold and we did not get it wet, so that would not explain the failure. I very carefully took the camera apart with a jewler's screwdriver and found that it is quite complex inside. To get to the zoom mechanism you have to remove 3 layers of circuit boards. Upon inspecting the zoom mechanism and the minature gear box I could find nothing obviously wrong or broken. Incidentally, don't try what some people suggest for other Fuji cameras about manually pulling the zoom out because you'll probably just strip the gear box. The mechanism is driven by a small motor about the size of a thumb-nail. I guess its possible that this had failed, but since I was not sure of the voltage and I didn't want to disconnect it, I didn't test it to see if it worked. I checked to see if there was any sand or grit in the mechanism but it all looked clean. When I put it back together the zoom mechanism extended and stayed there. The screen still showed "Zoom error". The only solution I can see is to buy a new camera of some sort. It seems that many of the Fuji cameras suffer from this zoom error problem so maybe a change of brand is in order. I think Fuji need to redesign their zoom mechanism.
Sep 12, 2005 | Fuji FinePix S3000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
74 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
