Question about Zanussi ZWF1430W Front Load Washer
Door gasket seal
How do i put it back on?
  • 54 Answers
Its a sod. it clips over the lip around the drum. belive me when i say i no techs who struggle with this. its each to there own way im afraid
Posted on Feb 14, 2008
GE fridge magnetic strip in right hand door needs to be re-installed, how can i do that?
The magnetic strip (very dark brown) is usually embedded inside a similar square hollow tube all the way around the door gasket. For it to have come out, there has to be a cut, slice or hole in the outer coating of the gasket. Press all the way around the gasket and you should feel the hollow spot where the gasket came out. It will feel solid where the magnetic strip is still in there.
Apr 04, 2015 | GE Refrigerators
Water drips out of bottem of door and i change the door seal
I have the same problem with my dishwasher. I have replaced the door seal and it still leaks. It seems like the channel where the seal fits is just a little too deep for the seal. As a temporary fix, I pull the door seal out of the channel about 3/8 inch on the side that leaks before closing the door to run the dishwasher. When the door closes, it pushes against the seal and that seems to work for me. A more permanent solution would to be to add about a 1/8 inch filler gasket into the channel then put the door seal back. That way the seal will press on the the gasket instead of bottoming out into the channel. Hope this helps you.
Dec 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
I have a 1989 honda accord dx with a oil pan gasket leak and a rear main seal leak, in order to fix the rear main seal leak, does the oil pan and the oil pan gasket need to be removed and does the gasket...
they don't use gaskets on oil sumps its sealant glue and yes u will have to reapply it when you put the sump back on, and what do u mean by main seal? do you mean the head gasket?
Nov 18, 2009 | 1989 Honda Accord 4 Door
Delfield freezer 6151-S ,replaced door gaskets and they don`t seal
Take a hair dryer (or take off the gasket and throw them in the clothes dryer (yes I am for real I do this all day long)) then put them back on. or the hair dyer way is keep heating the gasket up and holding the door closed while you do it. they should start to seal as you are pressing them together.
Sep 23, 2009 | Delfield Freezer 6151XLSR Stainless steel
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Sep 05, 2009 | Refrigerators
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
Door not sealing
After putting a new gasket on you will usually need to form it. You can use a hair dryer to heat the gasket and flat screw driver to form it.
Nov 07, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Zanussi ZWF1430W Front Load Washer Logo
88 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
