Question about Bose Lifestyle SA-1 Amplifier
Bose amp I have a bose amp, 175461-02 I need a user guide. Attempting to hook up this 3 room system but can't receive normal volume. When I pull up power the sound to speakers is a loud base sound and can't control volume at the individual room volume controls. sound is so loud afraid I am going to blow speakers. Need manual or suggestions?
  • Anonymous Mar 17, 2014
    can i set up two rooms with a yamaha ax396 amp to play two iPods so different sounds in each room?
  • Anonymous Mar 19, 2014
    Dear sir,
    My akai AA-R20 has some problem with volume control and balance control. I have to replace the two controls. But these days 250K V/R volume control with loudness control (4pin x 2 = 8pin)and 250K balance control not available. So need your kind advice to repair my amp.
    Thanking you,
    Ananda Pathirana
    Scholar:
  • 130 Answers
    President:
  • 1,944 Answers
Here is the manual.
Posted on Dec 30, 2007
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
I have a bose 321 system and I want to hook up HDMI cable, is there any way I can hook them up?
You must have been provided with a user guide/manual along with Bose 321 system . Follow the instructions on Set up 4 at page 12 wherein details have been given to connect HDMI cable along with the diagrams. Follow it. If you do not have the manual go to the following link and down load the manual in pdf
http://products.bose.com/pdf/customer_service/owners/AM312515_01_321_SeriesIIIandGS_OG_ENGvo.pdf
Sep 20, 2011 | Bose 3 2 1 GSX System
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Denon AVR 1910 Volume Level
My Pioneer VSX-36TX (circa 2002) does the same thing. Modern AVR's count up from minus something to 0db and go just a few db higher into 'plus' territory. It seems arbitrary but that's how it is.
Ask yourself this: who ever really turned the volume knob up to maximum on any amp on purpose, and had speakers survive it? In other words, why have all that capacity on a potentiometer if you never use it?
Little known fact: With that in mind, Bose Corp actually designed a product that intentionally used the full physical travel of a volume control - the Bose Acoustic Wave Music System.
Feb 11, 2010 | Denon AVR588 Receiver
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
Compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at danmc@uwyo.edu and I'll forward the pdf.
1-30-2009
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Bose Lifestyle SA-1 Amplifier Logo
800 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
