Question about Hotpoint TDC32 Electric Dryer
Hotpoint dryer TDC32
The empty water light on my dryer wont go off, the tank is empty but the stays on can you help
  • 22 Answers
I had this problem but it is NORMAL. only when the empty water light is flashing it needs emptying, i thought there was an internal problem but like i say it is normal to stay on solid throughout your drying and even when you just switch it on. i found this out in my manual
Posted on Mar 28, 2008
  • 770 Answers
Check the switch where you remove the tank towards he bottom
Posted on Jan 27, 2008
  • Gary Davd
    Gary Davd Jan 27, 2008
    please go to a UK product page for Hotpoint This was not made for the USA market I have no info on it nor do i think any of the other tech will
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Jul 23, 2010 | Hotpoint Dryers
TDC32 Dryer is running but is not heating up
Common fault with these is the two thermostats that fit on the heater at the back of the appliance -- accessable by unscrewing the back cover (MAKE SURE POWER IS DISCONNECTED FIRST!!)
There is a choice of thermostats depending on the serial number of the appliance.
If you need any other assistance please email me on:
Aardvark Repairs
Nov 01, 2009 | Hotpoint TDC32 Electric Dryer
Why does it take hours for the empty water light 2 go off
take that water pump off and clean it.this worked for me
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Empty water button staying on
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Plz rate my solution.
Jan 10, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Dec 13, 2008 | Hotpoint TDC32 Electric Dryer
1. see if you have 220 at the plug, the dryer will run on 110 but won't heat.
2. Check the heating coil, it could be broken.
Jul 02, 2008 | Hotpoint TDC32 Electric Dryer
No Water
One other thing some of the water in in a coils so if the dryer is new it will take some time to prime and fil the tank dont worry it wont heat when the tank is full and will tell you to empty the tank when it needs it ..hope this helps
Jan 26, 2008 | Hotpoint TDC32 Electric Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
451 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
