Windows problem windows just restarts over and over?
  • plumbcrazy Dec 30, 2007
    what if you don't have that disc?
    President:
  • 317 Answers
Put your Windows XP disk in, hopefully you're using XP. Then boot with the disk inserted.
It will say "Press any key to boot from CD" you press any key.
When that boots up, you'll press R to repair Windows. This will load the recovery console.
It will ask you to select your Windows installation, this should be "1" and then enter.
Type the command "fixmbr" without the quotes, then enter. Then "y" and enter.
Then the command "fixboot" and enter. Then "y" and enter.
Remove the disk.
Reboot.
This SHOULD fix your problem.
Posted on Dec 30, 2007
  • Peter Burns Dec 30, 2007
    You have to have the disk to do this, if you don't have it try to borrow one from a friend that has one.
How to restart windows 8 pc
to restart your Windows 8 PC:
1. Swipe in from the right/ press Win + C
2. Tap/ click on Settings
3. Tap/ click on Power
4. Tap/ click Restart
http://windows.microsoft.com/en-US/windows-8/restart-windows
http://windows.microsoft.com/en-us/windows-8/charms-tutorial
Jan 07, 2014 | Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
When trying to veiw photographs from dis using Winddows Live Photo Gallery I ger error code 0x80010108. I am running Windows 7 64 bit
My Start Menu>Control Panel>Programs and Features>Windows Live Essentials 2011- Right click>REPAIR Or Uninstall/REPair-Dialogue Box>Repair -Finish - Restart.
Re-Install Windows Live Essentials 2011, RESTART AGAIN Should work now.
May 05, 2011 | Microsoft Windows Live Photo Gallery
I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
The recovery manager must have damaged your windows installation
Sep 05, 2010 | HP Pavilion dv6000z Notebook
How do i reboot my windows vista
booboofayce3
To restart Windows Vista click on the Winows Peril or press the Windows button to bring up the Start Menu. Next click on the triangle that is to the right of the shutdown button. There you will get a drop down that has the restart option in it. Clicking on the restart will restart the computer.
Issken
Jan 11, 2010 | Microsoft Windows Vista Home Premium...
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Boots up then shuts down windows critical error and goes back and off again
This problem is basically because of faulty heat sink.However it depend when the sys. restarts. weather it goes to windows and then restart or it restarts before windows logo if it restarts after windows boot procees you can try to reinstall the OS. or else you might have to replace the heat sink.
Oct 31, 2009 | Computers & Internet
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
85 people viewed this question
Alun Cox
David Payne
David Payne
