Question about Protron PLTV-32 Television
Dark lines on the sscreen
I have a protron tv a little over a year old. There are two dark lines about a half in ch wide that run vertically from top to the bottom of the screen on the right side of the screen all the time.
  • 579 Answers
This indicates that there are bad connections in the cabling going to the display panel. Usually there are tiny connections along the top of the panel that rely upon pressure to hold the contact material to the panel contact and if the assembly is not right, gaps form in the picture like you describe. Sometimes just sqeezing on the units cabinet in the area of the gaps is enough to affect the problem. May need to go inside and work on the contact assembly.
Posted on Dec 31, 2007
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Silver lines about three inches wide run across top of screen on Sansu MTS tv. It's three years old and attached to a cable box. How can I make the lines go away?
You have bad capacitors next and near the vertical IC. You will also need to resolder the pins of the vertical IC. Check and replace capacitors.Find a capacitor checker to find these. If you know of a hobbiest or electronic tech, have them this for you! Thanks for asking and show a few hands of support!
Jan 16, 2011 | Panasonic Televison & Video
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
No vertical drive?? Quarter inch wide bar of light from side to side.
At nearly 5 years old its probably better getting a new TV, not only will you be getting much better new technology but paying for repairs on a tv that could breakdown again in 3 months and cost even more.
Oct 08, 2008 | Emerson EWF2704 TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Protron PLTV-32 Television Logo
101 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
