Question about Sony Playstation 3 (PS3) Console
Error 8001002b when i insert a game into my ps3 it says error 8001002b. Please help me mr guru
  • 6 more comments
  • Daks Jan 11, 2008
    game system was tripped over and bumped, now reads error 8001002B and won't load game, pictures where the saved games are won't load either... what can we do?
  • woogiebear Feb 24, 2008
    lost all saved madden 08 profile -- when i click load it says error 8001002B
    can you help??? also other saved games have turned into corrupted data....any suggestions?
  • Anonymous Mar 31, 2008
    same error
  • Anonymous Apr 05, 2008
    I have the same problem with Uncharted. After last sony update game wont boot and error 8001002b is displayed.
    same here
  • tattoo_30 Aug 16, 2008
    i put my ps3 on put the game and this come up ( an error occurred during the start operation 8001002b)
  • blake_snook Aug 20, 2008
    wat if the disc is not found
  • shikhar143 Nov 15, 2008
    same here
Wat if its showin up as a game and there is no update
Posted on Aug 20, 2008
    New Friend:
You have a corrupted file. Somewhere on your hardrive there is information from your game, and since its corrupt, you can't install the information.
Are you able to download it and have you installed it before, matters greatly in this example though.
If you've tried every safemode option including in your settings, then you 100% need a new hardrive, or delete everything on your hardrive. This is not a function Ps3 has in its options, nor will they tell you.
Somewhere on your hardrive is old info stored and corrupted and that is why you can't play. You must remove every bit of it.
Posted on Jul 09, 2013
    Problem Solver:
  • 5 Answers
Is it a ps3 game? generally that happens with ps2 games only, download and install latest software, v2.10 I had the same problem.
Posted on Dec 30, 2007
How do i fix ps3 error codes
the sony knoledge center on the web has a list of all the error codes and how to solve them
Dec 07, 2014 | Sony Playstation 3 (PS3) Console
Can not play games on ps3 error code 8001002b,what does this mean the machine is only 19 months old
This error code is a general error code. There is currently a maintenance going on with the PSN. You will need to have patience, as this maintenance would take a bit longer for it to be over. Every other gamer is experiencing this problem. Hope this helps
Apr 22, 2011 | Sony Playstation 3 (PS3) Console
I have a problem with my ps3 (ntc j ) it is 8001002b i need i solition plz think you
Hello moho16
This error refers to a problem regarding external storage devices. Try the following steps:
1. Try removing then re-inserting the storage device.
2. Try an alternate storage device.
If multiple storage devices produce the same error message, then you probably have a hardware problem, which will mean sending your PS3 in for servicing. If your PS3 is still under warranty, take it back to the retailer you purchased it from. Otherwise, check with your local Playstation website for instructions on how to send it back to Sony directly.
Hope this helps, good luck.
Sep 14, 2010 | Video Game Consoles & Games
Play station 3 wont load games keeps saying an
go to this link......
its a dirty/damage disc error.
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
How do i fix error 8002f1f9
1. reset ps3 to defaults using recovery menu. 2. begin installation using the same fw version. (hard disk must be formatted externally if u get error 8001002b)
3. when it hangs @ 73% or whatever. Shut down and remove the drive
4. begin the installation of the system inserting the drive into another ps3
5. after it reboots, press (PS), at the disclaimer shut down, remove the drive and put into the broken ps3
6. boot ask to format the drive...
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Error 8001002b gta4
try an dput alcohol on the disc and rub real good. if not working remove disc and replace it
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
My ps3 gives me two error: 80010514 and 8001002B, I tried it all.
go under settings then system settings then restore default settings
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Error 8001002B
That is the common "dirty disc" error. If it happens with every game, it more than likely means that your Blu-Ray diode is dirty. Do you have the PS3 in a dusty environment? Be sure to clean the vents on the side, above the USB ports and on the back of the PS3 on a daily basis. A quick swipe of a soft cloth will do.
You can try several solutions for your problem, the most common to buy a can of air and blow it inside the disc drive in hopes of cleaning the diode. You can also try a CD/DVD cleaning disc.
If it happens with every disc this could also mean a dreaded Blu-Ray drive failure, or in your case, one that is in the process of failing.
If cleaning it does not work, I highly recommend you give Sony support a ring.
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
I get the error message on my ps3 :8001002B
I Believe that this means you have a dirty disc. Try cleaning it and starting again if you haven't. IF that doesn't work then the disc has corrupt info on it or is damaged!! I hope this helps!!!
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
Error 8001002b
you may need the update for the sony and when you get the automated press 0
May 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,300 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
