Wacom Intuos3 Graphic Tablet
Problem for Wacom Intuos3 Graphic Tablet
Blue Light Not On
By pianoman0000 on Oct 22, 2009
I have a wacom intuos 3 tablet, and have owned it for about a year, using it about once a week. However, this week when I went to use it, I had no response from the mouse, nor the pen. The blue light on top is off and has not lit up, even if I plug it in a different USB hub. After downloading the new drivers (10/20/2009) and several restarts, as well as trying every USB hub on the computer, I still get no response from my tablet.
Comments:
Nov 02, 2009
- I should mention that I am running a laptop as well, powered out of a docking station. Should I let the battery die out on my laptop and then recharge it before plugging in the tablet again? Also, when I have the Wacom_tablet.exe, it pops up with a message after a few minutes saying "the tablet driver is not running." Finally, I have never received a USB not working prompt. Both my wireless mouse and keyboard, flash drives, and other USB devices are working properly. Thanks for the response, though.
Nov 02, 2009
- Hm. With all other external devices unplugged, I get no change in the Device Manager USB controllers whether my tablet is unplugged or plugged in. And I have downloaded the most recent drivers from a few weeks ago. I'll try the battery thing now.
Nov 03, 2009
- Well, no beans. I drained the battery and removed the battery, then put the battery back in and started it up. The light is still not lighting up. Also, when I try to run the prefrences executable, I get an error message that says "A supported tablet is not found on the system".
Clarification Request
Posted by tok_host on Nov 02, 2009
Had the same problem and just solved it. Very easy. Turn off your computer. Pull the power cable. Wait about 5 minutes. Plug it back in and power it back up. No more USB not working prompt in your device manager and your tablet should be back and running.
Solution #1
posted on Nov 02, 2009
Not Rated)
tok_host
Rank: Apprentice
Rating: 0%, 0 votes
Check out your Universal Serial Bus controllers in your Device Manager. If anything is amiss there I would suggest you turn the computer off and remove the battery. That would be the equivalent of pulling the power cable. All my other devices worked as well in all USB ports. Just not my tablet. I think once the box is turned off you can hold the power button down for a minute or so which (used to anyway) guarantees all power is discharged.
Comments:
Nov 02, 2009
- Check out your Universal Serial Bus controllers in your Device Manager. If anything is amiss there I would suggest you turn the computer off and remove the battery. That would be the equivalent of pulling the power cable. All my other devices worked as well in all USB ports. Just not my tablet. I think once the box is turned off you can hold the power button down for a minute or so which (used to anyway) guarantees all power is discharged.
And definitely go to the Wacom site and download the latest drivers. They have some very recent updates available.
Nov 03, 2009
- Well, I reckon the only thing left to try is if the tablet works on another computer. At least then you know if it's your box or the tablet itself.
Was this helpful?
Yes
No
Popular Solutions for Wacom Intuos3 Graphic Tablet
Questions and Unsolved Problems for Wacom Intuos3 Graphic Tablet
Do you recommend Wacom Intuos3 Graphic Tablet?
Answer
Answer
can i get a sepeate pen for intios 3 with extra nibs(pen tips)??Were can i buy tat?or pen nibs... (More)
Answer
Mouse will not work right on Intous 3, I have CS4 installed and my mouse won't click most of the... (More)
Answer
my tablet pen doesn't snap back to it's original position when i lift the pen and place it down... (More)
Answer
How can I get my wacom intuos 3 tablet working again? A few days ago it was working fine and then... (More)
Answer
Hello! My Wacom Intuos3 stylus keeps making intermittent (but increasingly frequent) sudden... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Wacom Intuos3 Graphic Tablet:
Top Graphic Tablet Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Graphic Tablet Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
