Question about RCA F32650 32" TV
Circuit board 1547266C
I'm looking for the part and can't locate it. The tv is a RCA F32650YX01. Where could I get it today (sunday) Located in Metro Dallas / Ft. Worth area. thanks
  • julied008 Mar 18, 2008
    I need the same replacement circuit board (1547266C). Did you find one? If so, where could I buy one, too? Thanks!!
  • JWomack94 Apr 13, 2008
    I've got the same problem, though a different TV model, its the same control board integrated circuit. Has anyone found one yet?
Thanks scottiez, it worked for me, pry the top open, unhook ribbon cable and take out circuit board (make sure tv is unplugged and then press pwr button a couple times before touching cb)
wiped it down with alcohol(90%) and pressed the buttons a few times and put it back together. You saved me from having to buy a new tv :)
Posted on Sep 21, 2008
Remove the board and clean it with rubbing alcohol while pushing the switches in and out. allow to thoroughly dry and reinstall.
worked for me.
Posted on Apr 26, 2008
Where are fuses located in RCA model SLD65A55RQ LED TV?
Fuse [Main] can be located at its power supply regulator [SMPS] board. There is a fuse at its T'Con board too.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 19, 2016 | RCA Televison & Video
Is there a way that anyone can tell me where the fuse panel is on a RCA Model #: R52WH74 television?
There is one fuse on the AC filter board which is where the power cord is located. Just trace the power cord back to where it plugs into the circuit board on the right side when looking in the rear you will see the fuse located right next to where the cord plugs in on that board.
Nov 16, 2011 | RCA Televison & Video
I have a model D52W23 and I have taken the back off but still do not see the bulb location. I see circuit boards but no bulb at this time. Is it located behind the circuit boards?
that model doesnt have a bulb it has three picture tubes. Chances are YOUR needING a deflection board for that model its the large board on the left side. You can get replacement deflection board from www.tvrepairworld.com
Sep 19, 2011 | RCA D52W23 52" HDTV CRT TV
Owners manual for rca tv f32650YX01 ENTERTAINMENT SERIES, XBOX READY, GUIDE PLUS
When I turn on the tv it makes a loud chirping sound, with no picture. What could cause this?
Sep 05, 2010 | Televison & Video
Polariod FLM 3232 no sound
The audio circuit is located on the main board. You might be able to find one on ebay or shopjimmy.com. Just search your model number and look for main board. Just look at the pic and make sure it looks like yours before buying one.
The most common problem for no audio on this set has been a 10ohm resistor located on the top right corner of this board that fails. The location number is r385, which will be stamped on the board beside the resistor. If it's open(bad), you could change it and save a lot of money.
Jul 30, 2010 | Polaroid FLM-3232 Television
Where is the dip switch located
dip switch is mainly located in computer mother board and ic circuit of tv
Feb 25, 2010 | RCA 24V511T 24" TV
I have a hdtv rca 42 tv
cmiggins: you are already doing part of what can give you the solution(at least general area)to the problem. Try to cool down the area of the tv or circuit you are heating up so it can stay on, by doing this you will isolate the general circuit or board where the problem is located. Once you have this, there are several web sites that can help you with a rebuilt or replacement board(s). please leave your feedback if i answered your question satisfactorily. thanks!
Aug 25, 2009 | RCA Televison & Video
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Circuit board needs replaced
I replaced mine, it's called the Deflector board. Some people call it the flyback board after the flyback transformer that is located on it. I found one on Ebay for 25 bucks a while back, so good luck. Troll ebay or find someone that is giving their tv away on craigslist because the convergence or a bulb is bad. Don't base it just on your specific model of TV though because many of them share this common board.
Try part #271827. That was the part number of the board I won on Ebay.
May 25, 2009 | RCA R52WH73 Projection Television
Where can I get the part?
Take your board to the local TV repair shop. They will be able to replace the individual micro switches and save you a small fortune replacing the whole control board.
Apr 13, 2008 | RCA F36669 36" TV
RCA F32650 32" TV Logo
334 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
