Dell Dimension 9150  PC Desktop
Problem for Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Dimension desktop 9150 was running very
By wbroyles2 on Oct 22, 2009
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in but the machine will not come back on. I took the cover off and the MagJack (ethernet) port on the motherboard is flashing red and yellow. There is also a green light which is lit solid on the motherboard. Help !
Solution #1
posted on Oct 23, 2009
Not Rated)
Compurepair
Rank: Wiz  Dell Expert
Rating: 84%, 786 votes
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 9150 PC
Questions and Unsolved Problems for Dell Dimension 9150 PC
Do you recommend Dell Dimension 9150 (DIM915MIN) PC Desktop?
Answer
Answer
epson cx 7800 how do i make it print black & white only? it is a color ink hog.
Answer
lab wont restart a disk read error accurred ctrl alt del wont work
Answer
connecting altec lansing speakers. 221 amplified speaker system . trying to connect to my compuer.
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 9150 PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
