Question about Radio Communications
Realistic I have a Realistic Pro 2010 base scanner. I need an antenna for it. What will work? Where can I get one? costs?
  • robertson697 Sep 22, 2009
    i have realestic 2010 scanner it have hi and lo scan what should i leave it on.
Any radio shack should still sell the base antenna for this. It is cat. no. 20-176. You will need coaxial cable, antenna, (2) pl-259 connectors with UG176 adapter and a pl259 to RCA Motorola adapter.
Posted on Sep 23, 2010
  • 204 Answers
Snickers1 hi, if I googled in the right scanner, yours is an older one with an antenna that screws into a stud inside the top cover. Here is a link to a site that has a lot of the older stuff covered. He's been selling CB stuff for over 30 years. You'll have to look at your scanner inside to see if it's male or female thread. I hope this helps with what your looking for,, Mechanic
http://www.kenselectronics.com/lists/amfm.htm
Posted on Jan 20, 2008
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
Looking for a manual for a Realistic Patrolman Pro 40 UHF/VHF Scanner. I don't even know what kind of power supply it needs.. LOL
Hi, that unit looks to be a mobile scanner and if I'm seeing right then you would need a Base power supply that could supply 12volt to it. Course you could also use a computer power supply and find the 12 volt line out on it. Here is the link to some spec's for it. Looks also to be crystal controlled so it cannot be reprogrammed. Good luck.
RadioPics Database RadioShack Realistic PRO 40
RadioShack Realistic Pro 40
Sep 06, 2015 | Radio Communications
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
I need codes for my realistic pro 2023 scanner
Codes? Assuming that you're looking for frequencies, you can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information by visiting:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 25, 2010 | Uniden BCT7 Base Scanner
Hi, i have a PRO 2025 Realistic Scanner, it is a
eBay has numerous antennas that will work for you, mostly in the $20 -$30 range. Here's a link to one of the listings:
http://cgi.ebay.com/NEW-MINI-MOBILE-SCANNER-ANTENNA-MAGNET-MAG-MOUNT-KIT-/220596857646?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335c98eb2e
You can also pick up a compatible antenna at any Radio Shack store.
Bill B
May 11, 2010 | Radio Communications
Well you will need to get it at Radio Shack,they just plug right in the back of it . nice ...hope this helps..
Mar 18, 2010 | Radio Communications
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Radio Communications Logo
293 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
