I have a posiflex CD-2860CCD bar code scanner that won't work with MYOB Retail Manager. I have taken it to a friend who also has MYOB Retail Manager and it works on his PC so it is not a faulty scanner. Is it a windows XP setting that I need to address as I have tried the Retail Manager settings with no luck?
I am using Motorola Fusion APIs on MC9090 for my program on Windows 5. The motorola API -...
(More)
I am using Motorola Fusion APIs on MC9090 for my program on Windows 5. The motorola API - fn_CommandFusionAPI CONNECTION_STATUS_WLAN_GET gives a very bad response time even when WLAN is active, it takes 4 seconds for this API. Is this a known issue?
Is het mogelijk ipv via de Seriële poort een keyboardwedge kabel aantesluiten op Dezelfde...
(More)
Is het mogelijk ipv via de Seriële poort een keyboardwedge kabel aantesluiten op Dezelfde scanner en indeien ja waar kan ik die kabel kopen
I have some Symbol PDT6846 scanners which had various hardware problems so we sent them off to be...
(More)
I have some Symbol PDT6846 scanners which had various hardware problems so we sent them off to be fixed. The boards in them have been replaced. Now what do I have to do to reload the programming? The message I'm currently getting is "Terminal cannot associate with AP. You're out of range or not configured. Ctrl-C to end or other key for retry. Halt Batch Process (Y/N)? I need to know how to set the IP address on the scanner, and how to get it to reload the programs. It appears to be trying to boot from D: where our other scanners are booting from E:.
When any barcode is scanned there is only a loud beeping noise to signal it didn't go through. What...
(More)
When any barcode is scanned there is only a loud beeping noise to signal it didn't go through. What needs to be done so that we can scan an item into the system?
