Question about Kenwood KVT-617DVD Car DVD Player
719DVD detected cable connection check cable
I have installed the 719DVD in a 2005 PT cruser and I get detected cable error and nothing else.
What causes the detected cable error?
  • 1 more comment
  • johnnyoutlaw Jan 02, 2008
    tks I've check the hideaway (brain) with DMM and looked between yellow and black 12.22 Vdc. The cable between the DVD and the hideaway looks new no noticable issue i.e. bent, folded connector, etc.
    tks.. the I've checked the power with a DMM between the back wire and yellow on the molex connector 12.22Vdc
    the cable between the headend and the hideaway looks intack and appears to be making connection.
    No smell, nothing hooked up backwards. I'm guessing, it must be a bad cable or one transceiver out at the headend or hideaway .. The store said no problem they are going to replace all three parts.
    Thanks
    JO
    Problem Solver:
  • 7 Answers
No power to the brain or cable is bad
Posted on Jan 02, 2008
  • skwid Jan 02, 2008
    i called kenwood about the same problem and thats what they told me. a cable is 80 bux and i found that my head unit had 12v hooked up backwards and the main board has a chip fried on it so i ordered a shop schematic on my unit to see if i can order the burnt component and replace to see if i can fix it. kenwood does not sell their boards.
    good luck, you could also smell the back of the unit and you should smell a distinct smell if yours is burnt. or try a cable. im going to pin my cable and check all wires for continuity just to be sure.
I have a 2008 pt cruser that jerks when i drive
If it is a standard you might want to make sure you are not indeed grinding the gears but if it is not a standard then you might want to have the transmission checked.
Aug 20, 2017 | Cars & Trucks
2005 p/t cruser my check engine light is on and the fuil gauge is going to emptey and full all the time
Go to Autozone,they will scan your light and tell you what is wrong,it's free and only takes a few minutes Cllaude.
Nov 07, 2016 | 2005 Chrysler PT Cruiser
Where can i locate chassis number on body on 2005 pt cruser
On a 2.4 PT It's found at the rear of the cylinder block, on a 2.0 it's found on front side of engine block.
There are VIN numbers on the dash board viewed through the screen. On the fire wall can be found the body code plate.
On the T350 manual transaxle the codes can be found on the transaxle end cover and on the G288, it's found on the transaxle bell housing.
Finally, on auto trans, it's found affixed to the trans axle torque converter housing. Have a poke about and you should find what you are looking for. some plates contain partial information, but all should match, as you know.
Hope you find this helpful. Red
May 15, 2014 | 2002 Chrysler PT Cruiser
Engine cutting out at 2500 rpm on my 2004 pt cruser and engine light is on ,problem comes and goes ,this is very frustrating on the highway
You can check the engine code by puttuing the key in the ignition...in rapid recesion turn the key to the on position and back to the off position 4 time ending in the on posistion. Wright the code down and search i on google or at www.autozone.com. Correct the error.
Jul 26, 2010 | 2004 Chrysler PT Cruiser
Troubleshooing pcm 2002 pt cruser
DEPENDING ON READER OR SCANNER, DOES THE INTRUMENT CLUSTER READ NO BUSS? IF SO IT COULD BE THE PCM THAT IS WHERE THE BUSS COM. COMES FROM, DOES THE VEHICLE ACT UP WHEN ENGINE COMPARTMENT IS HOT IF SO THIS IS A GOOD INDICATION OF A BOARD FAILUER IN THE PCM.
Dec 03, 2008 | 2002 Chrysler PT Cruiser
Kenwood KVT-617DVD Car DVD Player Logo
140 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
