When i go to print or copy and even when i close the cover where the toner cartridge goes, I get a "grinding noise" and the paper gets stuck in the toner cartridge.
Any ideas what might be wrong? I also have problem with a roller on the front edge of the paper trays which keeps getting knocked out of its holes.
Any ideas on this?
Thanks in advance for your help
Fuser drive gear is a mission to install
From memory the side frame has to be pulled off to allow access to above fuser drive gear
Photo from www.precisionroller.com
In the workshop I don't get the time to replace just the gear
most times I replace entire frame as pic above, it comes as complete unit(expensive) but is a lot quicker to fit.
If I can be of any more help, feel free to post.
Good luck
I took the back of the printer off and found that the fuser gear and the gear it meshes with are both broken. I ordered a new fuser and the gear and I am in the process of trying to put it back together.
I will certainly let you knoe how it works.
Thanks for your response.
I have it apart,put the gear back in. I have a long road ahead, gears are falling off all over the place. I think the diagram you posted will help. Thanks for including it.
If I cant fix it, i may end up buying a whole new multifunction. Ill let you know how it works out.
You've been a great help,
Thanks
Fuser gear has cracked, replace fuser is recommended although gear is also available on its own, but I find when replacing just the gear it cracks within 6 months again, due to the fuser bearings and other gearings making fuser tight to turn.
Not sure re roller, I can picture the one I beleive and all that spings to mind is to check and maybe bend a little the metal clip either side of roller I think you are talking about.. ie I think it is clear or white is 4 cm long about 1 cm wide held by two spring metal clips on paper cassette.
