Question about Viking DDBB363 Bottom Freezer Refrigerator
Door alarm i think my dooor sensor is broken. how do i change this part
  • Anonymous Jan 11, 2009
    pleas healp me home needs broke into
  • kandmsigns May 11, 2010
    How do you replace the circuit boards in a Viking/Amana bottom freezer refrigerator? Is it just un-plug the old and plug in the new?
    Thank you
    Sergeant:
  • 263 Answers
Http://www.repairclinic.com they have schematics diagrams and parts catalogs
Posted on Jan 01, 2008
My alarm keeps going off in my 2006 Toyota Matrix for no reason at all. How do I fix this?
Oh there is a reason and that is likely one of the door sensors on the door latches inside the door is going haywire and that makes the system think the car is being broken into. Have a scanner hooked up to see what sensor is doing this, they are called door ajar switches.
Jul 12, 2017 | Toyota Cars & Trucks
The dooor does not close and open after I have change the motor's battery,the motor only beep, what could br the problen
Try manual release and move door without the opener. If it moves freely , may be a problem with the drive motor or limit switches or even something blocking the photoelectric sensors.
Jan 12, 2015 | Building Materials
What does 3 flashes pause than 3 flashes over and over on a Viper 3105V one way alarm system mean?
The three-flash, wait, three-flash sequence indicates that either the nuisance prevention circuitry or another fault has been registered by Zone 3 or the door sensor. Nuisance prevention circuity is automatically activated when there are several faulty activation codes sent to a sensor. In turn, the door sensor is bypassed by the alarm which keeps the system quiet. This only happens when a specific threshold is reached in specific activation codes that are sent from the door sensor to the alarm cpu.
It would seem inadvisable to disable the door sensor when it is receiving faults. It might indicate someone is trying to boost your car. However, it is not as inadvisable as you might think.
The faults that activate the nuisance circuity tend to be lower-level faults and not the major ones that might trip the door sensor such as someone trying to slip the door lock or someone who might smash a window. In those instances, even though the nuisance circuity was tripped, the alarm will still work and sound, if it receives major faults such as the attempted to slip the door lock or the windows is broken.
The nuisance circuitry is meant to prevent the alarm from activating for multiple impacts to the door such as those that might be called during a high wind or if pieces of wood were blown against the car during a high wind.
Oct 30, 2014 | Vehicle Parts & Accessories
Door open sensor trips and alarm sounds
It's either the sensor itself or the wiring from the sensor to wherever it goes. I would start by swapping the two rear sensors and see if the fault moves to the other side. If not it's the wiring which you will need to trace and check all connectors involved.
May 08, 2014 | Ford Escape Cars & Trucks
Outside dooor handle
Replacement door handles are found at a Dealer, and Salvage yard. Some auto parts stores stock a universal car/truck handle on their "Help Wall"...Your interior door panel usually needs to be removed to switch out the handle. Most are held in place with 10mm head bolts...(2) What kind of car?
Apr 03, 2014 | 2006 Ford Focus
The alarm light stay's on but the alarm does not beep or set
It sounds like your alarm is in valet. Open any dooor, press lock, unlock, lock. The LED light should go off and you should be able to arm the alarm with the chirps active.
Apr 06, 2011 | Viper Vehicle Parts & Accessories
Door is closed and lock not working. How can I unlock and repair ?
pull off the door panel, feel inside the door by the lock and pull the rod that it connected to yourlock unlock switch on your dooor
May 11, 2009 | Mazda MPV Cars & Trucks
U 1 error message
U1 is a right cover open error. So either that cover is not closed all the way, the tab on the door itself is not hitting the sensor that detects if it is closed, the sensor itself isn't working properly and lastly it could be board malfunctions. Most times on this model it is either a broken tab on the door or it is not shutting correctly. The front door has to be completely shut before the right door will shut. If you are looking at the right dooor straight on the sensor is at the bottom left corner of the machine. There is a little **** in the plastic that is where the sensor is. There is a piece of plastic on a spring that is on a guide that slides back when "triggered" some times that can come off the guide.
Hope this helps.
Dec 31, 2008 | Panasonic DP-150A Copier
Help with wireless window security alarm
"Zone not ready" indicates the windows sensors are not seeing the magnet piece to indicate the window is closed. Are your sensors built into the window jams or are they external wires you can see?
If you have external wires, look for broken wires or broken/missing magnetic bars.
Did the painters paint the window jams? If so, they may have painted over a sensor, though paint usually does not affect the functionality of a magnetic sensor.
Look for the broken wires or broken/missing magnets.
Also - you should be able to bypass the window zones and set the alarm. Instructions for bypassing a zone should be on the alarm head or available online.
Dec 23, 2008 | Intermatic SP130B Wireless Door/Window...
Car Alarm/Door lock
This happened to me too...It turned out to be that my door was out of adjustment, which caused the door position sensor to not know whether the door is closed or open. Sometimes my light on the inside of the door would flash (because the car thought that the door was open). Once the alarm did activate, the car would sometimes think that the door had opened, thus causing the alarm to activate. It was cheap to have fixed...I think it was less than $100 at the dealership.
Jul 08, 2008 | Hyundai Motor 2004 Sonata
Viking DDBB363 Bottom Freezer Refrigerator Logo
150 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
