Toshiba cf3572b display issue
The picture that is displayed is too large for the viewing screen. Any text that should normally show on the top, bottom or edge of the screen only partially displays. If I play a DVD that is recorded in letterbox mode will display correctly. I have looked through the manual and tried everything that is supposed to change picture settings with no success. I have tried the Reset button and unplugging it overnight. Again, no success.
techman
  • 3130 Answers
SOURCE: Video will not turn off; "I2C-BUS STOP MODE" error at power up
Nope a very easy problem .. What it is is the relay is stuck on or closed so when you plug in the set the power comes up But the micro hasent told the rest of the set to work yet. So when you hit the power button. its just like you hit the power and it activated the relay and the rest of the set. Now in some rare occasions the driver transistor for the relay was shorted But most of the time its the contacts that weild shut, but you cant just clean them as it will work for a while, but in a month or so you will be in the smame boat. But if you not a tech this repair shouldnt cost you to much because if your not an experienced tech you can not only cause harn to the set but also you yourself BE CAREFULL and take the set to a pro!!!! Good Luck
Posted on Jul 27, 2006
Ipod_freak
  • 19 Answers
SOURCE: Picture is too tall
change the settings or go to the the store you bought it at
Posted on Aug 01, 2007
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: Our TV reset itsself to sales pitch
thanks , the solution you gave about the closed-caption option turning it off , worked .
Posted on May 25, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
The display on my toshiba nb505 went to the right of the screen. I can't reach the close x with the arrow anymore. What did I do wrong and hoe can I get the display to go back to normal ? Thanks in...
This is a common problem on net books. You can try playing with the resolution until the picture fits the screen again (that is often a resolution setting issue). To find resolution setting, right click anywhere on the desktop and click on 'properties', or 'personalize', whichever it shows, then 'Display' in bottom right corner. Good luck.
Feb 11, 2014 | Toshiba Turquoise 10.1" NB505-N508TQ...
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
How do I change the font or Text sizen
  1. Go into your Control Panel by first clicking on the Start Button.
  2. Then click on the Control Panel icon located in the right column of the Start Menu.
  3. If your Start Menu is set to the CLASSIC VIEW then begin by clicking on the Start Button.
  4. Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
  5. Now, Double click on the Display icon to open up the Display Properties Window.
  6. Then click on the Appearance tab at the top of the screen.
  7. At the bottom left side of the screen you will see an area to change the Font Size:
  8. Use your mouse to switch between normal, large and extra large according to your preference.
  9. Then click on the OK button to save your changes and exit Display Properties window.
  10. Windows XP will immediately adjust to your new Font Size without restarting your system.
  11. Then close the Control Panel to return back to your Windows Session.
Jun 10, 2011 | Computers & Internet
Picture too large for screen
mine did not fix, picture is still huge and pushed to bottom of screen so the top is black all the way across
/uploads/images/picture-large-screen-34901330-4-1.jpg
May 27, 2010 | Westinghouse SK-32H240S Television
Enlarged icons and text
The following should get you back to normal:
  1. Click the "Start" button
  2. Click "Control Panel"
  3. Click "Display"
  4. Click the "Settings" tab on the top
  5. Near the bottom is a box that says "Screen Resolution" , to make the stuff on the screen smaller , slide the bar toward the right and hit apply. You may need to slide it over a couple of times to make the display look correct on your screen.
That should fix you right up!
Sep 30, 2008 | HP Compaq Presario V6000T Notebook
Windows vista lare icons and text
In changing the icons to normal, did you reset the screen resolution? If not, set the resolution lower, apply, then reset it back to the original (usually 1024x768), then apply.
Aug 12, 2008 | Toshiba Satellite P105-S6207 Laptop
Toshiba M55-S135 laptop. Video on screen is 1/3 blue at top, bottom 2/3's are white
Sounds like ur screen needs replacement bud its going bad due to age this is normal for any LCD display to show its age
Apr 13, 2008 | Toshiba Computers & Internet
take zoom offf on dish and the tv it sel use normal 16 .9 ,mode when u push screen in to it use 1024x768 60 hertz ok
Jan 23, 2008 | Compaq Presario 1200,1600, Series CD...
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
