Question about RCA P52920BL 52" Rear Projection Television
No Power to Model # P52920BL
I cut off the tv one night. Now it want come back on. When the power is connected it just makes a clicking sound. Any suggestions?
  • tafnuef Jun 04, 2008
    My TV was fine last night and daughter said it took a while for picture to come on this morning and POOF it went off. Now we just hear that clicking noise.... You gave a solution to what it could be.. My step dad is an electrician would he be able to fix the problem.. can you give instructions?
  • 61 Answers
Sounds like the flyback transformer and horz output,the output shorts and the set will just tick when its pluged in to the ac
Posted on Mar 06, 2008
When powered on the tv makes a constant clicking sound
THe clicking noise is the relay on the PSB that allows AC to be sent to the psb. It won't hold in due to some fault either in a resetable link or some other safety component. To check this unplug the cord from the mains for an hour, then try again. You should hear the relay click once and then the TV will power on for a short period before powering off again. The solution is to replace the component, other than that replace the psb. I can't get a manual to prove this so I am just making an intelligent guess until I can prove it.
Apr 19, 2010 | LG 42LC2D 42 in. LCD HDTV
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv died last night no power at all no stand by light or sound It is a Samsung Tantus Model number TXN3298HF CRT
check first power ac cord by removing back cover trace if ac line voltage found, check for possible burn fuse. make a record after that scenario trace and log voltage trace from power supply ckt area.
Mar 26, 2010 | Samsung TXN3298HF 32" TV
Samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
LG 50 plasma
yes that was from that cut power you should go now to the authorized service to fix that problem
Dec 10, 2008 | LG 50PX5D 50 in. Plasma HDTV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
Problem with RCA 52 inch
The flyback has burned a hole in the side,it needs replacing
Dec 03, 2006 | RCA P52920BL 52" Rear Projection...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Open Questions:
See all RCA P52920BL 52" Rear Projection Television Questions
Televison & Video Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
