Surround speakers don't work
Hooked up new system, L, R, Center, Subwoofer speakers fine - surrounds not working on test or in use. Yamaha HTR-6030 5.1 Channels Receiver
  • 36 Answers
Hello barstep,
Let's go through some steps that will help alleviate your problem. We'll start from the simple to the not so obvious:
1.- Perform a visual inspection on the back of the receiver and verify that all speaker connections (specially the surrounds) are not loose, shorting out another connection or are pushed too deep into the speaker connector so the wire insulation prevents proper contact. If this is not the problem then...
2.- Get into your receiver's "Manual Setup" and verify that your surround speakers are set either to "SML" or "LRG" but not "NONE".
3.- Verify the receiver is not in "Straight" mode, shown on the receiver's display. I f so, press the "Straight" front panel button until indication disappears.
Your owner's manual can give you detailed information to access the setup menus.
Hope this information helps. Let me know if we can further assist you.
Posted on Dec 30, 2007
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Yamaha Surround Sound HRT-6030
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
Yamaha HTR-6030
The indicator is telling you you have a 2-channel input. You may have the Blu-Ray connected wrong. Or the source is only Stereo. I need more details to assess that.
The sound coming from all speakers is normal if you have any surround mode selected, regardless of the characteristics of the source
I imagine if you experiment you might find all speakers playing for any number of 2-channel sources, not just Blu-Ray. Besides actual Pro Logic decoding, the various surround modes can provide some interesting effects on non Dolby Surround material.
I recommend that you try them all on various recordings and you may find one or another of them preferable over vanilla stereo. I find that any given artist or music type, even within a given CD, may sound 'better' with different surround settings.
Dec 27, 2008 | Yamaha HTR-6030 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
81 people viewed this question
