Question about Sony KP-65WV700 65" Rear Projection HDTV
Blue bulb fickering on and off and stays off
When im watching tv the blue bulb keeps flikering on and off and then stays off. I turn the tv off for an hour or so and then its fine for a couple of day but then it starts up again.
    President:
  • 4,402 Answers
Http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Posted on Jan 23, 2008
When im watching my fire tv stick it keeps flashing onto a blue screen then flashing back to what im watching how do i fix this
It just does this with the fire stick, regular TV is ok? If that is the case the fire stick is most likely defective.
Jan 10, 2017 | Amazon Fire TV Stick
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
When i turn my computer the screen stays black and flikers for a bit
The problem is in the inverter board located below the LCD screen, or the built in backlight behind the display. I would hook a monitor to the video output to rule out the video graphics chip.
Jun 24, 2012 | Lenovo Computers & Internet
The tv keeps randomly turning off, now i cant even turn it on, the light goes blue but the screen stays black
Sounds as if your back lights are not lighting, and that points to the high voltage power board. You may have the dreaded capacitor failure. Start with http://www.youtube.com/watch?v=YfO-KCQIYXQ&feature=related and look around.
Jan 27, 2011 | Dynex DX-L42-10A 42 in. LCD TV
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Infocus 61md10 wont boot up
Unplug it from power source for an hour to two hours reconnect and turn on
Aug 16, 2009 | InFocus ScreenPlay 61" Rear Projection...
TV wont stay on.
Similar problem with my Sony. unplug for 36 hours and try again
Aug 13, 2009 | Samsung HL-R6767W Replacement Lamp
My nintendo 64 wont workon my tv!!
First you must be sure that the connection on your tv is securely connected.
Mar 08, 2009 | Nintendo 64 Console
T.V will automatically turn on and off during the first 10 minute
With projection TV's the lamp is usually the cause for cycling issues. The lamp power supply (ballast) monitors the current drawn by the lamp and adjusts voltage to keep the current at a specific value, if the ratings fall outside of spec the TV will cycle power and attempt to correct the anomolie. If this happens too many times within a specific time frame the TV can refuse to turn on and will indicate an error code. Don't put the TV through too many retrys or you could damage the ballast too.
Lamps can cost between $200 and $400. The ballast can cost anywhere from $150 to $250 approximately. Usually the manufacturer of the TV will sell you a new bulb, but electronics suppliers often sell them for less. Most lamps are owner replaceable and easy to do, consult your owners manual.
In-home servicers can base their labor charge on the size of the TV. The larger the TV, the higher the labor cost. Do it yourself and save!
Hope this helps.
Feb 15, 2009 | Vivitek Televison & Video
Sony KP-65WV700 65" Rear Projection HDTV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
