Question about Polaroid FLM-3225 32 in. LCD Television
Volume problem I had volume on my tv and then i walked away and then my daughter said that it stopped could you give me some ideas to solve problem
  • Anonymous May 06, 2008
    i have no sound on hdmi inputs only. regular cable input has sound. any ideas?
Similar prob with our tv. Our tv volume is all the way up, and our verizon fios set box volume is all the way up too. Can hear it as if you were watching tv in bed and didn't want to disturb the other person sleeping.
We bought the warranty (told to by several friends) so will let you know after the repairman fixes it in a few days.
Posted on Feb 21, 2008
Walking belt slip, sliding away!
You need to replaced the walking belt and have a professional reset the drive belt to the proper tension.
Aug 01, 2017 | HEALTHRIDER S300i Treadmill Motor Control...
Bose Cinemate Sr1 volume keeps auto turning off when not in use
Hi, All. First, thank you for suggestions posted. Next, I have unplugged both the subwoofer and the center channel speaker, left them unplugged for a minute or two, then re-plugged them in. However this did not correct the problem for me. When I pause the television for five or 10 minutes for example, the Bose volume automatically shuts off. This is a major inconvenience. I suppose if nobody can address this issue with the remedy here, I shall have to call Bose and see if they can assist. Any other ideas or suggestions? Meanwhile thank you very much.
Apr 03, 2013 | Bose Cinemate Digital Home Theater System...
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
Internet want start
Hi mtaylor9,
Routers are great but they do have issues with distance, or certain walls that can interupt the connections. My suggestion is to have your daughter when she is connected to walk away from the router step by step, and continue this until it drops. This will give you the distance it will work for you. Then either move the router closer to her destination, or you can get another router than can act as a passthrough. The last option is to run ethernet wire everywhere which really defeats the purpose of wireless.
Good Luck
Mark
Feb 23, 2009 | NetGear WGR614 Wireless Router
Toshiba 35a44 Tv keeps going to demo mode
let the card be cleaned with sprit, some contacts are still holding down.
that will solve your problem
Nov 12, 2008 | Toshiba 35A44 35" TV
Sound
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Mar 03, 2008 | Sony KV-27V42 27" TV
Volume problem
http://pettersservice.com/polaroid/docs/FLM-Series-26-32-37-ServiceManualFinalNA_20070418.pdf
it says to replace the control box for no sound.
thats the main board to you.
I would use external speakers as they sound better anyway.
Jan 24, 2008 | Polaroid FLM-323B Television
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
TEAC Television -CT-M809AV -no picture
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Oct 11, 2007 | Sylvania 6419TE 19" TV
Polaroid FLM-3225 32 in. LCD Television Logo
146 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
