Question about HP Pavilion F1703 17" LCD Monitor
Screen goes blank after 2 seconds! - HP Pavilion F1703 17" LCD Monitor
  • homy Dec 31, 2007
    It is the monitor's problem, not the PC. I need some help from people with HP f1703, having the same problem.
  • orlandodiva Aug 09, 2008
    i also have the same black out problem screen lights up for a second and the power light goes from blue to yellow like it does when it goes into hibrnate .i am afaid to try the sodering iron because i have never used one before and is there a special type that i need? hp should be the one fixing this problem so many people with the same problem and they don't want to do $hit
    Genius:
  • 2,985 Answers
Blank Blank or can you see shadows?
If you see shadow images then the backlight or inverter has failed
If it is blank blank then graphics card or connector/cable problem
Does that help
Posted on Dec 30, 2007
  • swaffordrand Feb 25, 2012
    My screen is doing the shadow thing but the intro will still light up.
    Can you tell me what's going on with that.
    Thank you
    Thank you
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: screen shows for 2 seconds then goes blank, if
The probelm can be bad power supply due to bad caps (bulging top), bad inverter circuits, or bad lamps. Open it up and post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 21, 2010
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
budmrtn
  • 11361 Answers
SOURCE: monitor displays for about 2 seconds then screen
The problem can be caused by bad caps (bulging or leaking) in the power supply, bad inverter back light circuits, or worst case will be lamps. Look for bad caps first since it is easy to see, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Most monitors will fail after 2 years.
Posted on Feb 22, 2010
budmrtn
  • 11361 Answers
SOURCE: When I turn on my
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
Touch screen on acer z290 goes blank after 2 seconds
mine after few second turns off.
cpu remains cod and fan is working and nothing getting hot on matherboard.
Feb 23, 2012 | Acer Veriton Z290G 185 320GB
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Jan 20, 2009 | Samsung SyncMaster 940N 19 inch LCD...
HP Pavilion F1703 17" LCD Monitor Logo
423 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
