Question about Astar DVD-3100 DVD Player
No image i can`t see image on my 3100 dvd player, it run you can hear the voices but no image; i tried with others tvs, other rca cables but nothing;  it use to work very very nice can you help me?
  • Alberto357 Jan 05, 2008
    I have the same problem now, after dealing with the "set up". I think I choose either Pb or Pr on the screen set up and now I can't see anything. The sound is there. If I just would have the owner's manual, but my wife doesn't remember where she put it. It' s a manner of just checking the sequence of "Set Up" in the remote, via the manual, that is. I think!
    jose_alberto_p@hotmail.com
Ok, ¡lo tengo!
I solved! Press Setup once. Then, press once the Right Arrow; (This will put you in "Video"); Press ENTER. Press twice, (2), the Down Arrow, (Now we are in "Video Out"),Press ENTER. Press three, (3), times the Down Arrow, then press twice the Up Arrow; ENTER. (You are now in S-Video).
From here you should have Video, now make sure that the TV System is in NTSC, or Automatic. LET ME KNOW IF IT WORKED FOR YOU AS IT DID FOR ME, PLEASE!
¿En español? jose_alberto_p@hotmail.com
MAKE SURE THE REMOTE IS DIRECTLY IN FRONT OF YOUR DVD, NOT AT AN ANGLE!
Posted on Jan 06, 2008
How do i conect a dvd player to a Model UE32C5100QW
This will depend on the output type(s) of your DVD player.
If the outputs on the rear of the DVD player are Yellow (vodeo), Red and White (left and right audio) then you will use standard Composite RCA cables running to the A/V inputs of matching colors on the rear of your TV.
If the DVD outputs are Red, Blue, Green (video) and Red and White (audio) then you will use Component RCA cables leading to the appropriate inputs of matching color on the rear of your television.
Both of these methods will produce a standard definition image and you made need to adjust your television to get the image to display properly. You will also need to use your remote to switch to the appropriate input you used.
In some cases newer DVD players may have an HDMI output and you can use that to connect to one of the HDMI inputs on your TV. However, this will still produce a standard definition image although the DVD player or your TV may "upscale" the image to try and produce a sharper and cleaner image.
RCA cables, both composite and component, are available at retail stores such as Walmart, Best Buy or other electronics retailers. You can also find them online via Amazon, Newegg or other electronics retailers. Most shouldn't cost much and probably considerably less than a quality HDMI cable.
Feb 28, 2015 | Televison & Video
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
I have a cable TV connection, analogue, no hdmi, how do i connect dvd player and my other speakers to the TV?
You could purchase an "RF Modulator" box (a very small electronic box) which is designed for connecting DVD players to TVs which have only a coax cable input. The 'RF Modulator' box needs to also have the external audio connections ('RCA plugs) for diverting the audio signal to your external amplification (other stereo & speakers). These RF Modulators are found at most stores, and run $16 - $25.
Feb 05, 2011 | Philips Televison & Video
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Could hear the chanels good but no pictuere
Hello
1. Check the video connection of any devices plugged into the television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
2. Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
3. Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
4. Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
5. After all the steps and it does not come on then you would need to visit a technician.
BEST OF LUCK
Dec 15, 2010 | RCA TruFlat 27F520T 27" TV
Venturer dual screen dvd player for car
Hi and welcome to FixYa,
Initially, could be:
  • cable/connector problem;
  • 12VDC power supply/regulator;
  • monitor itself. Could be tested with another external video source and a shorter RCA to RCA cable.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 11, 2009 | Power Voice System Venturer 7" Portable...
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
Astar DVD-3100 DVD Player Logo
194 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
