My tv went out and I think I may have blown a fuse or something else went out. When I press the power button the green light turns on for a couple seconds and then just goes out. what do you think the problem is and what will it cost to fix roughly
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE
SET: press and hold BOTH the menu and input buttons at the same time
for at least 5 seconds and then release both.
This is the self check
this model has---power light should blink a two digit code---for
example--two blinks, a pause and two blinks and the set will repeat the
error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED 2 blinks and then 2 blinks is short protect
ETC.....Let
me know if you get an error code and I will tell you what the problem
is---hope you find 2,2 that is the most common and the most easy to
repair.
