Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Over flow Sometimes, without warming or without a change in how we set it up to grind beans, the coffee with overflow all over the kitchen counter. This has happened so much, I now have a plastic tray under the Cuisinart Grind and Brew all at times... Not very pretty. Coffee is good, but not great. I wouldn't mind all the cleaning if the coffee did not over flow at it's own will.... I can not find any reason... I did exchange the coffee maker after the first few times it overflowed, but the replacement still overflows !!! I would like to know what the Cuisinart warrenty covers ???
  • 1 more comment
  • Anonymous Jan 08, 2008
    Having the exact same problem with the overflow at will grind and brew.
    Less water has not helped the issue for us. It over flows whether we use beans or grounds. Just when we think we have the balance right and we don't have problems for a couple of days it does it again.
  • Neal Doherty Oct 30, 2013
    try using a paper coffee filter every morning as grinds build up in steel filter over time. Also clean the top thoroughly where the newly grinded beans are transferred. The problem is residue from previous use.
  • Anonymous Mar 18, 2014
    Coffee beans do not grind
    Problem Solver:
  • 13 Answers
Try using a paper coffee filter every morning (instead of steel) as grinds build up in steel filter over time. Also clean the top thoroughly where the newly grinded beans are transferred. The problem is residue from previous use.
Oct 30, 2013
Posted on Oct 30, 2013
I think you have to be careful in how much water you put in. I had the same problem the first few times I used it. I started to only fill until the water just met the 10 cup mark, not over it. I have not had the problem since.
Posted on Jan 03, 2008
What we discovered was that coffee grounds had gotten into the cap of the coffee pot itself-plugging it so that the coffee was not running into the pot but all over the counter-very frustrating!! We took the cap off and really shook it under the water all different directions and got globs of grounds out-doing that once in awhile has gotten rid of the prolem we hope. We do have the problem of the machine shutting off several times during brewing-having to restart again and again. We cleaned with vinegar-hope it works.
Posted on Feb 04, 2008
  • rrbrambley Jan 30, 2011
    I tried this... it seemed that a lot of "globs" came out, but the next day when we went to make coffee, the same thing happened. It is incredibly frustrating.
Coffee beans setting too small
* Brand and model needed for specific solutions.
* Check your warranty. Call for support
*** Following is for information only.***
* Bean grinders have a dial in front or a dial near the bottom of the been funnel (or bean bin.)
* Dials usually have size settings and may even be marked for the style of coffee to brew.
* Some of the smaller grinders have a dial around the collar of the bean container that have numbers or arrows pointing to coarse or fine grind. Some use a whole bean icon then smaller sand grind icon. Others may use numbers like 1-10 etc.
* For the super automatic coffee/espresso brewers they usually have a program enabled grind setting where a mini motor will adjust the grind for you depending on your coffee choice.
* The lesser "home" or office brewers may only have one setting and needs to be calibrated each time you change beans. (This is usually an adjustment knob or screw) Coffee needs to be brewed and tasted for each change of grind setting.
* Note that often changing the grind setting will also affect the ground coffee volume. (changing the size of dregs 'puck'). This also changes the flavor profile.
* Volume changes to brew needs to be done from the programing menu of the super automatic brewer.
* Espresso brews using a standard portafilter, it's critical to adjust the grind to the portafilter basket and dose water amount.
* Brewing in the coffee auto drip needs to have larger grind and more coffee to make up for the loss of flavor from large grinds.
* Smaller grinds intensifies the flavor but brings on bitter oils if ground too fine.
* Go slow and make taste tests each step of the way. Understand that it's a multi level balance between; Heat, Water volume, Flow rate, Pre-soak, coffee roast, coffee amount, besides just the size of the coffee grind.
* Calibrating for espresso; https://www.youtube.com/watch?v=FUeCLypvlNU
* Arrows and numbers; https://www.youtube.com/watch?v=n8dJpATLrjw
* Mazzer; https://www.youtube.com/watch?v=mN_To2nv1Fs
* Delongi; https://www.youtube.com/watch?v=WTYhZoncLBk
* Delongi(super); https://www.youtube.com/watch?v=OUSXo0xaHIM
* 890TS (also Bunn); https://www.youtube.com/watch?v=QF-kiFymTQM
* Size to brew; https://www.youtube.com/watch?v=5BCDIas33y0
* Electronic dosers; https://www.youtube.com/watch?v=xMadMBgMcA4
* Hand grinder; https://www.youtube.com/watch?v=zyCHdG25JFU
* Ceado; https://www.youtube.com/watch?v=iwHdm5GtNHI
* Modern hand grinder; https://www.youtube.com/watch?v=oH2s6rQ43us
* Saeco; https://www.youtube.com/watch?v=C7nK9nsFNkQ
* Breville; https://www.youtube.com/watch?v=1lGFJoI77T4
* Gaggia; https://www.youtube.com/watch?v=5U3o9jMvI3g
* Call your vendor for additional advice.
Aloha, ukeboy57
Aug 19, 2018 | Coffee Makers & Espresso Machines
COFFEE COMES OUT TOO FAST
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Jan 07, 2014 | Starbucks Saeco Italia Digital Barista...
My coffee beans are not finely ground and hence the coffee is very thin. I have washed the grinding parts and there is no improvement.
I think this is a manual for your machine
http://kitchen.manualsonline.com/manuals/mfg/saeco_coffee_makers/saeco_royal_professionals_espresso_machine.html?idRes=171679
May 19, 2012 | Saeco Royal Professional Espresso Machine
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
My super jolly mazzer grinder is switching off after only a few seconds grinding. used to grind continuously for however long i needed, now i have to turn it on 4-5 times just to get enough for one shot! ...
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
ukeboy57
Nov 07, 2017 | Mazzer Coffee-grinder SUPER JOLLY Electric
Our coffee maker overflows,coffee grinds get in coffee and overflows.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Sometimes coffee maker overflows
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
May 21, 2009 | Bunn NHB Coffee Maker
Over flow grounds without a cause
I have had two of these machines (warranty return) and they both did the exact same thing. Here is what I have discovered the problem to be.
The lid for the carafe gets stick and internally jams. As another poster suggested clean it thoroughly (this sometimes works). I have another solution. Call 1-800-726-0190 and explain that you lid jams and leaks all over your counter. They will send you an new lid for free no questions asked. They obviously are very aware of this situation and don't even ask for proof of purchase or purchase date.
Jan 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
340 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
