Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca52 d52w20 52 in. rear hdtv won't power on ????
When the unit is turned on either with the remote or by using the front panel, the power light flashes 3 tmes then goes off. The TV does not do anything.
  • appiah Jan 01, 2008
    when i switch on the tv the lights comes green and goes off.
Definitly the lamp, had same problem on same tv
Posted on Dec 30, 2007
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
I have a Hitachi 51F510. When I power it up it clicks like it always has and the power indicator light in the front comes on but it has no picture or sound. The remote will power the unit on but after a...
You need to follow power cord inside the set; should be a board on right side it goes to----this set uses up to 3 small black relays---one or more is bad---tap on each until power light goes out.
if questions let me know.
Mar 11, 2012 | Hitachi 51F500 51" Rear Projection...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD-62725 green light blinking
Hi Scott,
May I know if the unit stuck to green blinking led at the front panel and the unit won't come on?
Jdvillanueva
Dec 05, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
TV will not power on. We have had not problems to this point, it just won't turn on by either converter or using the tv's power button
Please let me know if the unit is totally dead set without the led light at the front panel at all.
Jdvillanueva
Jun 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Our RCA52 wont turn on. The green light comes on
Replace the CP150, CP120 and CP114 capacitors. You can get that repair kit from www.tvrepairworld.com whicj also contains the instructions.
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
Front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Aug 21, 2007 | Mitsubishi WS-65611 65" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
