Question about Acer AL1916W 19" LCD Monitor
Moniter turns on for 2 seconds turns off
When i power the moniter on the logo shows and the windows page shows and then turns black will not come back on untillturn power off and back then same happens agin. the model is al23032w
  • baden5 Jan 07, 2008
    when I set up my new monitor, it worked fine for an hour or two.
    Then I ran into the same problem.
    The monitor went black. When I turned it off and then back on the Acer
    logo shows, and then it showed the windows page for a couple of
    seconds, and then goes black again.
    Surprising, in that it worked fine for an hour or two.
    Any help??
    Champion:
  • 238 Answers
Hi guys, first run the system in safe mode, and with vga mode, see if it is the same problem ?? let me know
Posted on Jan 10, 2008
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Computer see the monitor
if the moniter is an Acer brand, the logo could just be the moniters sceensaver and not the actual computer. If you have tried other computers and connections that you know to be working it would seem to place the fault with the moniter. try googling the brand and model of the moniter to see if there are any known faults and fixes.
Dec 11, 2009 | Computers & Internet
I have an Acer AL2017 20inch. As of recent the
try these steps - in this order:
  1. Download the latest drivers for your video card but do not install it yet.
  2. Uninstall any video card software installed (ati catalyst/control center - nvidia etc)
  3. go to device manager, expand video adapters, and right click to uninstall them both.
  4. Reboot your pc. Windows will install a generic driver when it boots up. From there, install the new video drivers you downloaded in step 1.
  5. Get the monitor driver here: http://www.zdnetasia.com/downloads/pc/swinfo/0,39043052,50002410r-39518824s,00.htm and install it
  6. That should fix it. Let me know what happens.
Aug 08, 2009 | Computers & Internet
I hooked up this moniter turned on the power and nothimg black
My Dell monitor is showing odd splotches of colored bars.....turquoise bars and pink bars. What is causing this?
Apr 21, 2009 | Computers & Internet
KDS Moniter
Have you checked your video card or adapter?
Check the settings on the monitor itself.
If you didn't find the problem go into system properties (windows logo + pause)/hardware/device manager. Expand monitor/right click and see if your new monitor is listed. Is there a yellow or red symbol next to it? This would mean a problem, then right click symbol/properties and error will be shown.
Could be a memory issue.
Don't forget to try a "working monitor". This will narrow it down a bit.
Jul 14, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Screen on moniter is not full
I think that you need to reinstall or find a new driver for it.
Sep 02, 2006 | E-Machines eMachines Monitor E15T4
Acer AL1916W 19" LCD Monitor Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
