Question about Maytag UMV1152BAS Microwave Oven
Microwave won't heat.
Everything seems to work on this less than 2 year old Maytag Microwave, except it won't heat.
  • 579 Answers
Magnatron is suspect. Need to put a voltmeter and see if the input (primary) side to the high-voltage transformer (big heavy iron thing in there) is getting 120Vac. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Dec 31, 2007
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave jes1451bj02 will not work
The problem is the magnetron, or the inverter board, "if 7 years old or less"
May 12, 2012 | GE Microwave Ovens
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 1 yr...
If it's less than one year old, it would be fully covered under warranty and you should contact the manufacturer to get it fixed free.
Some have longer warranties, and that will be covered in your owner's manual.
Jan 31, 2010 | Maytag MMC5000 Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Maytag UMV1152BAS Microwave Oven Logo
119 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
