Question about Canon PIXMA MP160 All-In-One InkJet Printer
2E4 problem This printer has falling and repaired,after a time the code 2E4 on screen. Who can tell me what is the problem?
Hi i bought a new toshiba satellite C660-2E4 without windows but cant install windows xp~i get the 'blue screen of death' and stop error 0x00000007b log.searches through the web tells me to...
Go into your bios or setup and make sure your drives are set to Auto. Then look thru to see if are any settings that references AHCI and change it.
Save and retry the Install.
Apr 02, 2012 | Toshiba Computers & Internet
A key bunch fall in the paper loding slot and stuck inside cannot take it out tell me how open the cover?
If you are willing and physically able, carefully turn your printer upside down. Any foreign objects should freely fall out of the feeder. You may have to slightly shake the printer if the key won't fall out.
Jun 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
What is the repair code of nashuatec dsm615?
please tell me what is your code in this machine -thanks
Dec 22, 2010 | Gestetner DSm615 Digital Imaging System
I have a lexmark x543 that always has the message "std bin full' when it is not.
if you look where the black rollers are on the out put bin top rear of the printer to the left there is a flag this is what causes that error. it is either sticking or broken. lift up on it and make sure it falls back freely if the flag is not damaged change the sensor. i have to to tell you 95% of the time the flag is sticking or broken. out of a few thousand repairs ive only had to change that sensor twice.the mount for that flag just clips into place it can be dislodged fairly easy check to make sure the mount is not loose
Nov 23, 2009 | Lexmark T632 Laser Printer
I have an error code 1-2070 the printer print off
Go to kodak website and download latest drivers for Scanner. It will/should also tell you how to repair pictures.
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I HAVE AN ERROR CODE
To solve use this steps carefully.. Follow these steps.....
  • On the printer's front panel, press the ENTER key.
  • Using the Arrow keys, scroll to Utilities , and press ENTER.
  • Press the ENTER key and the Up Arrow key simultaneously (allows access to the Service Test submenu).
  • Using the Arrow keys, scroll to Bail Calib , and press ENTER.
  • The bail will rise.
  • Press the Up Arrow key until the bail makes a slight falling motion (approximately 1/4 inch). Each time the key is pressed, the bail will rise slightly.
  • When the bail makes the falling motion, press ENTER to write the calibration value to the EEROM. This is the correct up position for the bail.
  • When the message SUCCESS CALIBRATION press ENTER appears, press ENTER.
  • Press the PREVIOUS key until the main front panel screen appears.
  • Turn the printer off, then on to store the calibration value in the EEROM.
  • Turn the printer on and load media
Thanks
Aug 14, 2009 | HP DesignJet 450c InkJet Printer
Canon IRC-3200
hard drive problem. with the machine turned off hold down the 1 and 9 keys. turn on whilst holding down 1 and 9 and wait. the screen will go black and after a while the screen will have a white block falling down. when the blocks start falling you can take your fingers off the 1 and 9. the machine is performing a defrag of the hard drive and when the screen is completely turned to white it is finished. can take 20 - 30 minutes. when finished turned the machine off at the side and turn back on.
this usualy works 90% of the time, if it doesn't you will need a new hard drive.
May 05, 2008 | Canon CLC 1120 Color Copier
I990 cannon
Your printer is telling you it has an operating error, many printers give flashing lights as error codes to tell you what is wrong. If you visit the cannon website for your area, they will be able to tell you exact error code. If you do not want to do this, give me some time and i will be happy to help by finding the error for you. To help me, post back with what your printer is or is not doing correctly to get the error in the firts place. lilacgerry
Jan 01, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
156 people viewed this question
old marine
old marine
