Question about Amana ALG331RAW Gas Dryer
No heat Dryer runs at first with heat then quits? What can I do?
  • TAZ4284236 Apr 27, 2008
    I have a Kenmore Mod #110.72832101 gas dryer, when you first use it it has heat then about 5 min later it make a funny rattle noise and then there is no heat, what could that be?
    Problem Solver:
  • 14 Answers
Replace heat relay switch?
Posted on Jan 01, 2008
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
Dryer quit heating. still runs though.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 22, 2010 | Whirlpool LER4634J Electric Dryer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
My Roper dryer quit running...it's heating but doesn't seem to come on or tumble.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
Stopped heating
What I do is see if their could be an obvious reason for the dryer to quit heating. I determine how old the dryer is and ask if the heating element has been replaced and when, those sorts of questions then that give me an idea. I make it a point to clean and oil any dryer I work o. They all are going to have lint buildup in them and this lint is the main cause of heat failure. A small piece of lint gets on the heating element and causes a hot spot. The hot spot burns through interrupting the circuit93b855d.jpg
I unplug the machine and remove the rear cover. 1c9e8bc.jpg I 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element
(if you do not have a meter remove and inspect this heater coil for breaks). I remove the lint chute(that the thing the filter lives in) and I wash that out because it gets clogged over time. I check the heater and limits for continuity. Then I remove the front panel and drum. Completely vacuum out the dryer and oil the rollers. d4f393f.jpg
If this is a gas dryer you want to see if power is going to the gas assembly
If this fuseeda36f9.jpg is blown on a gas dryer the dryer will run but the heat will not, If the dryer heats a little but quits then these coils are getting hot and intermittent94fb1fe.jpgif your igniter is blown a54d451.jpgor your sensor is open5650218.jpgthere won't be no heat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2010 | Whirlpool LER5636P Electric Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Amana ALG331RAW Gas Dryer Logo
103 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
