Question about Dell Inspiron 1200 Notebook
Bad monitor Need to get data from laptop. Have hooked up external monitor but get nothing on external. I'm assuming there must be some setting to change but i can only see the top 1/3 of the laptop monitor.
  • learjet45 Dec 30, 2007
    fn+f8 did the trick...you da man!!!!!
    President:
  • 317 Answers
When you connect an external monitor, you might have to toggle it over to the other monitor.
It's probably on the F8 key, it will say CRT/LCD. You'll hold down the Fn key + F8 key and this will toggle to the external monitor.
Posted on Dec 30, 2007
  • Peter Burns Dec 30, 2007
    Glad I could help! :-)
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
Wrong monitor HP F2105 goes black after two secs when connected to HP G72 Laptop?
If the monitor works fine when tested on another device like if you have a desktop or a friend will let you hook it up to theirs, etc. then I suspect the laptop does not have a compatible driver or just cannot drive the monitor with the onboard video card. That monitor may be too much work for the laptop. Also, have you looked into how much just the lcd would be then maybe see if you can get help installing it yourself?
Nov 20, 2011 | HP f2105 21" LCD Monitor
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Screen is black
Hi
Thank you for your query
The problem statement is vagur however am i right to assume, nothing comes on the screen even when powered up???
If so it would seem there is a LCD fault, most likely to do with the inverter, this is replaced quickly and normally isnt too expensive
In the mean time if you need the stuff on your laptop please hook up a external monitor and backup your data
Thereafter please book into a reputable PC shop
If this has been useful please leave postive feedback/vote
Feb 12, 2010 | Toshiba Satellite L305-S5907 Laptop
My computer will power up, I can hear the fan working etc, all things are a go and there is even sound when I hit butons etc. it appears to be working but my screen is black
Plug in an external monitor to your laptop, if you see an image on the external monitor then your laptop screen is bad. It could be the screen itself or a video inverter.
If you can't see an image on the external monitor, then your video card on the laptop may be damaged.
Good luck
-Carlos:
Jan 06, 2010 | Computers & Internet
Starts, fan comes on but nothing on screen
DId yuo try connecting your laptop to an external monitor (via DVI port on your laptop)?, if not try that. If it works and you can see image, then you have a problem with you laptop's display. In the other hand, if you see no image through the external monitor then I'm sorry but you have a bad motherboard (most likely, the graphix processor has gone bad and since it is embedded onto the motherboard you have to replace the whole part). I assume you live in Europe (that laptop was very popular in England), if you need any parts, I would try ebay. Hope it helps, good luck.
Jan 05, 2010 | Computers & Internet
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Since the laptop works on the external monitor, then it would be safe to assume that it is only the L:CD display part that is the issue. Often LCD display (of laptops) are working but only that you can see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Toshiba.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
In some worst case scenario, it could be the video interface or even a loose/open flat cable from the laptop's main body towards the LCD display panel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | HP Pavilion dv9000z Notebook
Dell Inspiron 1200 Notebook Logo
238 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
