Question about Motorola Mobility H500 Wireless Headset
H500 how do make the led in standing pairing mode?? please help
How do make the led in standing pairing mode?? please help
Posted on Mar 18, 2008
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
Pairing Motorola h500 With Sanyo 2700 ,the sanyo can't find the H500
Make sure the head set is also in pairing mode. and also make sure you haven't already paired it previously. if it still won't find it it is incompatible or defective
Dec 05, 2009 | Motorola Mobility H500 Headset
I want to pair the motorola H500 to my blackberry pearl. i cannot get the bluetooth in pairing mode?
-Be sure the headset is fully charged.(plug it in till the light turns off.)
-Hold the talk button down for 4 seconds or until the blue light goes solid (not blinking.)
Now the device should be ready to pair with your Blackberry. It usually only stays in pairing mode for a short while (approximately 90seconds)
Jun 30, 2009 | Motorola Mobility H500 Wireless Headset
I can't get my motorola h500 to pair to my nokia 2865i
To pair the headset, first turn off the headset if it’s not already off, hold the multi-function button until the LED light turns solid blue (not blinking blue) with an audio indication, then use your phone to discover and pair with the headset using “0000” as the default pass code.
May 13, 2009 | Motorola Mobility H500 Wireless Headset
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
H500 will not pair/find with LG Shine
Turn the LG Shine off, wait 10 seconds and try again. Power cycling the phone really does help sometimes. Let us know if this doesn't work.
Feb 15, 2009 | Motorola Mobility H500 Headset
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
I have a problem with my bluetooth H500
You need to full charge both units first before to try them again. YOU MUST KNOW ONE MAIN KEY HERE IS THE BLUETOOTH HEADSET MUST BE IN PAIRING MODE WHICH IS MEAN THAT THE LED MUST IN STANDING MODE NOT IN FLASHING MODE AND WHEN THE LED OF THE BLUETOOTH HEADSET IS IN STANDING MODE, BRING IT CLOSER TO YOUR PHONE AND BE SURE YOUR PHONE BLUETOOTH FEATURE IS ON AND BE RECOGNIZED FROM OTHER DEVICES. Try to restart carefully step by step each device as described above and then if you still can not get them pairing then either on eof them has Bluetooth function impaired. You need to have another Bluetooth Headset to test whether your phone Bluetooth function or the Headset has it. Good Luck
Mar 30, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
135 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
